question for those who have the addco RSB..
Old Nov 29, 2000 | 09:41 PM
VQdriver's Avatar
i noticed that there was a bracket on each rear suspension arm holding what looks like the ebrake cable. if i remember correctly its a 10mm bolt. should i loosen or remove this bolt and let the cable loose? right now i didn't touch the ebrake cable and it sits tightly around the U bolt of the rear sway bar. doesn't seem like it interferes, but i was just wondering in case i wanted to adjust the bar setting slightly..
Old Nov 30, 2000 | 11:00 AM
SmoothMax's Avatar
OG
I think I know what your talkin about. I left the cable alone. I did loosen the 10mm bolt in order to get the brackets behind it, however, when finished I tightened it back. I say leave it as is cause you don't want to loosen it or leave it hanging because it might catch on to something. IMO
Old Nov 30, 2000 | 11:06 AM
Eric L.'s Avatar
Hmm..I remember reading about having to loosen the e-brake cable, but when I installed my Addco RSB the e-brake cable wasn't in the way at all so I didn't even touch it.
Old Nov 30, 2000 | 01:18 PM
dwapenyi's Avatar
Addco RSB Install
When I installed mine I used pictures from the web, like MegaMaxe's website and someone else's I beleive. All of them had the u-bolt on top of and around the e-brake cable, and I copied that install. It makes sense since th e-brake cable only has a steel wire in it, so tightening things around it won't hurt its functionality too much, unlike if it was a hydraulic line . . . . .
DW
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
