Hamburger on back...
Old May 18, 2002 | 05:31 PM
madmax97's Avatar
How hard to remove, what needed to remove, does it leave anything behind or if done well looks like was never there...any info would be great thanks
Old May 18, 2002 | 05:39 PM
02SM520's Avatar
Carpet cleaner
or
50 / 50 mixture of woollight + water..
Old May 18, 2002 | 09:49 PM
Draino's Avatar
first take an ordinary blow dryer and let it run on the emblem for a little while. Then take some strong dental floss and kind of "saw" it off. It should come off pretty easily, then heat it up again and use googone on the left over glue. Right after it is off make sure you wax where it used to be, give it a good two coats. It will probably leave a little mark but will go away after a while.
Old May 19, 2002 | 01:11 PM
KWheelzSB's Avatar
Before you do any of this, be sure to wash the burger and surrounding area with warm, car-soapy water. This will ensure you're not flossing any grit/sand residue trapped in the crevices back and forth against the paint surface while you're working the floss. . .
When I did mine, I was able to remove any sign that it was ever there. Goo Gone, Bug & Tar Remover - either can be used with a clean cloth/towel to remove any residue after you floss the badge off.
Follow this with a cleaner polish, like from Meguire's or Mother's. Apply 1 or 2 times, or until all traces of residue are gone.
(While you're at it, do the whole trunk-lid, so it's even - or better yet, do this on wax-day & do the whole car).
Then, apply a couple coats of cleaner wax or finish wax (Again, I've had great luck w/ either Meguiar's or Mother's brand products)
When finished, sit back & enjoy the fruits of your labor!
Old May 19, 2002 | 02:53 PM
LeX's Avatar
LeX
Nissan by Nature
*bonk* i'm so stupid, at first i thought he was talking about a hamburger on the back seat that had gotten into the leather or something lol till i saw the blowdryer bit
Old May 19, 2002 | 04:19 PM
Draino's Avatar
haha yeah those pesky back seat hamburgers can really creep up on you.....
Old May 19, 2002 | 07:31 PM
NickStam's Avatar
Floss, 3M adhesive remover, and a blow dryer
pocketrocket
26
May 14, 2002 05:48 PM
JJW95SC
Oct 9, 2001 12:38 PM
sickmen
Aug 30, 2001 06:23 AM
