Post SAE dyno ratings!!
Old May 19, 2002 | 08:32 PM
MarcGXE95's Avatar
POLE: Post SAE dyno ratings!!
Please only post SAE corrected #'s
Please no spam and no questons, only post your Year, auto/man dyno #'s and "your mods". (Edit for updates)
Old May 19, 2002 | 09:03 PM
Toolrocks's Avatar
95 Max SE 130,000 (hard miles) Stillen pop and Warpspeed Y pipe. 5 speed. Dyno was taken w/ car in 3rd on a Dynojet 248C
71.4 degress 29.36-0.44 in.Hg.
The numbers
Max Horsepower 177.4 at 5180 rpm
Max Torque 186.3 at 4490 rpm
I don't have a way to scan this in yet but my torque curve is fairly flat 2-3 k rpm then spikes to 184 at 3300 then drops at similar rate back to pre 3300 #'s at 3600 then produces a much broader curve that peaks at 4490 and then drops like an anvil after 5300. SO my torque curve is flat,spike,gradual curve.
Horsepower curve is fairly linear w/ a slight increase from 3100 - 3300 rpm then falls back a bit and then climbs again (linearly) 3800 to 5300 where it hangs flat until about 5700 where it starts to slowly drop.
I'd like to see more of these posts. When I get a chance I'll try to edit all me text w/ a graph.
Old May 19, 2002 | 10:17 PM
Dave B's Avatar
Not DAVEB the parts guy
DynoJet 248C
SAE corrected (correction factor 1.01)
4th gear
183hp @5400rpms
193 ft/lbs or torque @4500rpms
Mods:
HKS intake, UDP, Warpspeed non-mandrel bent Y-pipe, Stillen B-pipe, RT cat
Dave
Old May 19, 2002 | 10:32 PM
shortchaz's Avatar
SAE correction Factor 1.00
170.5 fwhp @ 5350rpm
188.0 fwtq @ 3250rpm
Mods(at time of Dyno)
JWT intake
Old May 20, 2002 | 07:51 AM
dwapenyi's Avatar
172 HP
184 TQ
Mods, CAI Hybrid, RT Cat, Cattman SS Y, that's it
Old May 20, 2002 | 09:44 AM
shortchaz's Avatar
Dude, something is weird, I am making more than you are and I only had a POP intake at the time of dyno. You only make 2 more hp and I am 4 ft/lbs above you.
Old May 20, 2002 | 10:48 AM
iansw's Avatar
155hp
180tq
What the heck is worng with my car?!?
I have a Y-Pipe and POP and MEVI.
Without the MEVI, tq is only 160.
IanS
Old May 20, 2002 | 11:55 AM
dwapenyi's Avatar
Maybe it's the Cattman Y pipe. Gotta check it.
DW
Old May 20, 2002 | 12:00 PM
Nealoc187's Avatar
SLOW
181.9 hp
189.4 tq
cattman y-pipe, JWT Pop charger.
Old May 20, 2002 | 01:01 PM
iansw's Avatar
Originally posted by Toolrocks
No cel? Cheap gas? Bad plugs? I remebered reading this in the VI threads but thought you eventually said it was the uncorrected reading. Are you losing oil? Maybe you should do a compression or leak down test? Altitude? Good luck. I'd figure it out before I put the S/C on it or you might be disappointed w/ that.
No CEL
Only buy Texaco 92 or 93, depending on where I get gas
Plugs are brand new NGK Plats (3k on them)
No oil loss whatsover, had it changed a week before the Dyno.
Compression is 10:1...perfect.
Altitude is 200 feet.
My car also feels perfectly fine.
It could still be the Dyno. On another run at another place, I got the same numbers, but then the guy mentioned that the way they were doing it is the "more correct" reading and not the way "most" people do it.
We re-did the Dyno the "usual" way and it came out to 169hp and 185tq.
So maybe it was the Dyno....still worries me, that's all, because I don't know what to believe.
IanS
Old May 20, 2002 | 06:25 PM
MarcGXE95's Avatar
People dont be shy, I'm shure there is more dyno's then that for gen4!
Old May 20, 2002 | 09:59 PM
BEJAY1's Avatar
Conecarver
188 hp
203 tq
97SE 5sp "If it bolts on I'll take one to go please"
Old May 20, 2002 | 11:58 PM
Toolrocks's Avatar
Originally posted by BEJAY1
188 hp
203 tq
203, I gotta know. What do you have? Sorry if it's in sigs, I have them disabled, but 203? S/C, NOS?
Old May 21, 2002 | 03:06 AM
Keven97SE
191 HP
200 ftlbs
Clicky here for my dyno plot:
http://maxima.cardomain.com/member_p...605_1_full.jpg
Old May 21, 2002 | 05:54 AM
BEJAY1's Avatar
Conecarver
No S/C. No NOS. All motor baby
CAI, UDP, ECU, Y-Pipe, Cat, B-pipe, Muffler. Actually too much power sometimes
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
09maxshawn11
Sep 30, 2015 10:28 AM
MichMaxFan
Sep 30, 2015 09:18 AM
