"WAI Blows Too Much Air & May Cause a Gasket to Blow"??
Old May 20, 2002 | 06:21 PM
97MaXiMaGLE97's Avatar
I had some problems starting my car recently, and i just had the 60,000 mile service tune-up. I took it to the dealership, cause they reset the timing at my tune-up, and my dad thinks that is what was causnig my car not to start sometimes. Well, the dealer gave 3 reasons:
1.) they reset the timing to the wrong thing
2.) I was flooding the car
3.) my k&n intake blows to much air into the oil, something like that, and that can cause an oil gasket to blow........i think that is total bullsh*t. Has anyone ever experienced their intake causing a gasket to blow? The guy at the dealer said that he has had 5 problems like that in the past month.....he also said it was like a $700 job too.
Old May 20, 2002 | 06:30 PM
iansw's Avatar
That's soooo absolutely not true. If he had had 5 of those in a month, then this board would have seen 500 of those this year already.....at LEAST 1000 subscribers on this forum have Pop Chargers....
I also have replaced that gasket before....it's about a $100 job, NOT $700.
Go to another mechanic...QUICK!!!
He's trying to rip you a new one....
IanS
Old May 20, 2002 | 06:34 PM
mzmtg's Avatar
Minister of Silly Walks
Also, they did not reset your timing. There is no way to adjust the timing on our cars, it is programmed into the ECU.
Please buy a Haynes manual and do your own work from now on. That way you won't get sacmmed and lied to.
IanS
I knew he was lying, cause people run turbos, superchargers, and nos....and a little damn intake will blow a fuel gasket??? I didn't pay him or plan to, i just wanted to know....thanks
Old May 20, 2002 | 06:39 PM
iansw's Avatar
Show him a picture of TurboMax'es Dyno at 400+ horse...then tell him to f*ck off!
IanS
Old May 20, 2002 | 06:40 PM
IanS
Old May 20, 2002 | 07:49 PM
NotNew!!NewSN!!'s Avatar
an n/a car cant "blow" too much air into ur engine, it can only bring it as close to 0 vacuum as possible if not 0.
Old May 20, 2002 | 08:21 PM
pro's Avatar
pro
Hi,
Any idea on where I could get this manual?
Thanks,
Paul
Old May 20, 2002 | 08:26 PM
iansw's Avatar
Pretty much any Auto Parts store.
Shucks,Kragen,Pep Boys.....etc...
mtrai760's Avatar
'Trynna' is not a word
check out www.amazon.com and look for Haynes Manual, Nissan Maxima. They have em' pretty cheap.
Originally posted by pro
Hi,
Thanks,
Paul
Old May 20, 2002 | 08:55 PM
pocketrocket's Avatar
Tell me I'm correct when I say an intake doesn't blow air in to the engine. The air is 'sucked' in to the cylinder chamber.
The fact that you've got an intake means you've got less restriction than the stock airbox but that just helps your engine to breather easier.
Unless you have a s/c of course
Old May 21, 2002 | 04:48 AM
Does anybody have any idea why my car has trouble starting? It turns over, but it just won't start. It seems like it's flooded, but i don't put my foot on te gas before i start it. Any suggestions or help???
Old May 21, 2002 | 05:05 AM
mzmtg's Avatar
Your starter or alternator or battery could be dying...
Old May 21, 2002 | 05:14 AM
I just put a brand new yellow top optima battery in about a month or so ago, and i had my alternator replaced last year. My radio and everything else works, my car just keeps turning over, but doesn't start. And i notice that it usually happens in the morning...
Old May 21, 2002 | 05:25 AM
mzmtg's Avatar
Have you replaced your muffler bearings?
Old May 21, 2002 | 05:30 AM
No, seeing how i've never heard of that......that would cause my car not to start?
Old May 21, 2002 | 05:42 AM
mzmtg's Avatar
KaleCo sells replacement muffler bearings. Look in the "Replacement" section...
Old May 21, 2002 | 05:51 AM
njmaxseltd's Avatar
Re: "WAI Blows Too Much Air & May Cause a Gasket to Blow"??
You guys know what the really sad part of this post is?
They actually have service advisors working that have no clue of how the cars they service actually function.
Reset timing? You'd think Nissan would train this guy before allowing him to speak to customers.
Flodding the car? OK it's remotely possible with a FI car, but come on lets get real here.
And the best, the K&N intake is BLOWING to much air into the engine? HELLO!!!!!! Somebody point this service guy to www.howthingswork.com
Old May 21, 2002 | 05:53 AM
Re: Re: "WAI Blows Too Much Air & May Cause a Gasket to Blow"??
SO i can't flood my car, because it's a fuel injected car.....that;s what i thought the problem was, because when i finally get it started i smell a lot of gas.
Old May 21, 2002 | 06:23 AM
I am sorry, i misheard the dealer....well actually he talked to my father, and that's what my dad said he said. But, i talked to the dealer today, and he said that the popcharger sucks too much air and oil in and could have cause me to blow an Air Flow Meter sensor. Does that sounds more realistic????
Old May 21, 2002 | 06:37 AM
rmb's Avatar
rmb
Well, in some defense of the a-hole, that could happen if you over-oil the filter. Over-oiling should be avoided in any case.
But there still:
Is no timing adjustment. Not for many years now on just about any car.
Flooding? Next thing he'll tell you he needs to rejet your carbs and adjust the float levels.
Find another mechanic.
Is your check engine light on? Was it on? Have AutoZone try to pull some codes.
I'd replace the coolant temperature sensor for kicks. The same symptoms happened to me and threw no codes. The sensor wasn't dead enough to self-diagnose as dead....
-RMB
Old May 21, 2002 | 07:56 AM
speedtrip's Avatar
An over-oiled air filter could have coated the MAF sensor element. There was a post about this not to long ago.
Remove the MAF sensor. Take a flashlight and look at the sensor. It is a thin wire running in between two larger wires. Similiar to a filament on a light bulb. If the sensor filament wire is dirty carefully clean it. If you break that wire then you have to buy a new MAF sensor and they are expensive.
Old May 21, 2002 | 09:24 AM
dwapenyi's Avatar
If your MAF is dirty, buy some electrical parts cleaner from Radio Shack or other electrical store. Take the MAF off, and just blast it with the parts cleaner. I did that to mine just for the heck of it. My car was running fine before I cleaned it, I just did it b/c the MAF has been running like that for over 80,000 miles.
DW
Old May 21, 2002 | 09:35 AM
tomj's Avatar
That was your first mistake, but it can be dealt with. If you are smelling alot of gas then I wonder if they screwed up replacing the fuel filter. Maybe the line is blocked and that's why the car is stalling. Or maybe they put on a Sentra's FF.
Old May 21, 2002 | 08:12 PM
tom_98se's Avatar
Um..
What about the non-starting problem...
Turning over but not starting doesn't seem like a starter problem. Seems more like a fuel delivery or spark problem. Will a dirty fuel filter limit flow to the point that the engine won't start (from starvation)? What about a dying fuel pump not delivering enough pressure?
And the muffler-bearing thing was just plain mean
Regards,
TOM
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
Justin Kroll
Oct 1, 2015 07:03 PM
MichMaxFan
Sep 30, 2015 09:18 AM
