Strut bars do they help?
Old May 22, 2002 | 03:37 PM
i30dude's Avatar
Im thinking about buying one, but do they really help? I mean can i feel the difrence? thanks
Old May 22, 2002 | 03:43 PM
Jeff92se's Avatar
I'm needing a caw
yes and yes
Old May 22, 2002 | 03:46 PM
i30dude's Avatar
Originally posted by Jeff92se
yes and yes
What kind? Are the ones on ebay any good?
Old May 22, 2002 | 03:53 PM
Jeff92se's Avatar
I'm needing a caw
http://forums.maxima.org/search.php?...der=descending
Old May 22, 2002 | 03:56 PM
eelcram's Avatar
Re: Strut bars do they help?
It definately does.
Old May 22, 2002 | 05:05 PM
gtr_rider's Avatar
192.168.1.1
OH yes it helps, and yes you feel it. I can now cut turns like bimmers, well not really
Old May 22, 2002 | 06:12 PM
95emeraldgxe's Avatar
- get an rsb and stiffer suspension and you can =]
Old May 22, 2002 | 06:26 PM
Vyrus's Avatar
I agree, although many people on this forum will deny it, I think a Max with a fully modified suspension (FSTB, RSB, springs, struts, possible RSTB) can outhandle a Bimmer.
-Cyrus
Old May 22, 2002 | 06:29 PM
gtr_rider's Avatar
192.168.1.1
Will do.
Old May 23, 2002 | 05:22 AM
Albertt's Avatar
Just in case you are still in doubt... >>
A bit more opinion on the subject...
Old May 23, 2002 | 05:25 AM
rguida's Avatar
Re: Just in case you are still in doubt... >>
FSTB and RSTB and rear sway bar = a nice feeling everytime I turn my car.
Old May 23, 2002 | 06:30 AM
MChapel's Avatar
Forget E-Bay. There are probably dozens of places in the greater Chicago area where you can get a good FSTB for less than $100.
Anything more than $100 and you're either paying for a "look" or buying a FSTB designed for serious road racing.
Old May 23, 2002 | 02:32 PM
Yossarian's Avatar
-Cyrus
you forgot subframe connectors and polyurethane front sway bar bushings, end links and control arms... well, with all those you're handling much better than any stock BMW
Old May 23, 2002 | 04:14 PM
95maxrider's Avatar
Lightly modded
to be honest, i didnt feel any difference when i put it on. then again, it has a 1/2 inch cut on it....
Old May 24, 2002 | 06:54 AM
Albertt's Avatar
95maxrider, why does it have a .5in cut on it? nm
nm
Old May 26, 2002 | 09:59 AM
95maxrider's Avatar
Lightly modded
cause it was used...the other guy scratched it. it has no effect on its performance
Old Jun 10, 2002 | 12:49 PM
jensyj's Avatar
Re: Re: Just in case you are still in doubt... >>
i only have the FSTB.
now i'm thinking of buying either the RSTB or RSB.
i hear people say that the RSTB doesn't really do much. HOWEVER, the rear sway bar appears to be a big improvement.
should i get the RSTB or RSB?
please advise.
many thanks,
FSTB and RSTB and rear sway bar = a nice feeling everytime I turn my car. [/B][/QUOTE]
Old Jun 10, 2002 | 12:56 PM
MDr's Avatar
MDr
Re: Re: Re: Just in case you are still in doubt... >>
Get RSB.
It will make the car more stable thru turns.
please advise.
many thanks,
[/B][/QUOTE]
Old Jun 10, 2002 | 01:36 PM
Mark Reilly's Avatar
Re: 95maxrider, why does it have a .5in cut on it? nm
nm
You better believe it helps! But still, don't get to overconfident on those tight turns.
Old Jun 10, 2002 | 02:17 PM
ptatohed's Avatar
Licensed to Spell
:o)
I can't beleive how many of you think you can 'feel' a Front Strut Tower Brace. The power of the mind...
No i30, you won't feel it but heck, for $50 you'll sleep better. Go for it.
Old Jun 10, 2002 | 03:16 PM
exhip95's Avatar
Re: :o)
I really felt mine but how much others feel it depends on which model Max. I have a GLE which has a soft suspension. My front end didn't lean as much and felt much more stable especially when only one side of the car would hit a bump like a man-hole cover. The steering also felt heavier...more connected. If you have an SE you may not feel as big a big difference.
Old Jun 10, 2002 | 03:32 PM
spiff56747's Avatar
Why would you pay anywhere near $100 for a strut bar? I got a pretty good one from ebay for $30 + shipping, if i remember correctly.
Old Jun 10, 2002 | 03:37 PM
ptatohed's Avatar
Licensed to Spell
Re: Re: :o)
I have a GLE too. I'm not trying to sound rude in anyway but I garauntee you that anything you (or anyone here) feel/felt is in your head.
Old Jun 10, 2002 | 03:58 PM
exhip95's Avatar
Re: Re: Re: :o)
How can you guarantee something like that? YOU may not have felt anything because there is something in your head (joke) but I most certainly felt it.
If you have one on, take it off for a while and go for a drive. Then put it back on and drive the same roads. You should feel it.
Too many people had good results with them so I'm sure it's not mass delirium or something...
Old Jun 10, 2002 | 04:40 PM
ptatohed's Avatar
Licensed to Spell
Re: Re: Re: Re: :o)
I challenge anyone to have a friend randomly flip a coin and remove/install your FSTB while you are not looking. By driving the car around your favorite course, you state wether the FSTB is installed or not each run. If you get at least 8/10, I'll be extremely impressed and I will apologize. But I'm sure no one can. And if you are willing to come to S.D. and let me be 'the friend', I'll even bet you $100.
Old Jun 10, 2002 | 04:46 PM
Jeff92se's Avatar
I'm needing a caw
It's sutble but I felt a difference. Before in a long sweeping turn, I would have to constantly input steering correctings. After the need to row the steering wheel back and forth was reduced a bit. Not too much but noticable. Thing is, it would probably take someone who is pretty familar w/ your car to tell the difference. Hell if they didn't make a difference, why do they come on Q45s/Skylines as oem equipment? Also the Integra Type R I believe.
Old Jun 10, 2002 | 06:17 PM
exhip95's Avatar
Re: Re: Re: Re: Re: :o)
Too bad I'm in FL. If I was I S.D. I would take you up on that bet!! Easy money.
I know the way MY car handles intimately. I would probably be able to tell the difference just pulling out of my driveway.
Either way I sleep pretty good...
Peace
Old Jun 10, 2002 | 07:42 PM
RastaManMax's Avatar
Those who push their car hard regularly will feel the difference, those who don't, won't... It's as easy as that... So if you drive at 15km/h down the road and go into a turn and say you feel a difference, you deserve a *****slap; however, if you drive at 150km/h down the road, and say you feel a difference, that is normal...
Pnjboyzz
Nov 16, 2015 12:27 PM
MaxLvr21
Oct 17, 2015 12:11 PM
maxima-junky
Oct 7, 2015 06:13 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
