DOes a Rear Sway bar make that big of a diff
i was thinking about getting one... but i was thinking of putting that money towards a cai..
does a rear sway bar significantly improve the handling or is it barely noticeable
I bought mine in the Addco group deal, and I think that it is a steal worth every penny. The my Maxima feels like a diffrent car, now I can't take corners like nothing. I strongly suggest you get one.
Approximately 45min, it's very simple to install.
if i had the choice, i would rather get CAI first but the RSB does a good difference when it comes to turns...you'll definitely feel it but you'll feel and hear the difference in a CAI much more...both are worth it though....
Originally posted by meccanoble
yea, and it would been a lot easier if we didn't have to bend some of the screws...took me and my friend approximately 1 hour and a half being we didn't know how to fit things and being it was our first time...
Bend bolts? I didn't have to bend anything. Everything went well. As far as intake, I already have one, and it is louder than my exhaust.
as for the sway bar, it was the biggest suspension difference i felt on the car besides FSTB and RSTB.
Originally posted by rguida
What exhaust do you have?
Even after lowering your car......
.....does an RSB make a big improvement on handling/cornering, etc? how about the Front and Rear strut tower bars? It seems to me that my lowered car has already improved in handling, but will the bars still further improve it? will it make my ride any harsher?
What do you mean by stiff? stiff as in handling/cornering or stiff as in stiffer, harsher ride from the back end?
I've heard that the car makes weird popping noises w/an RSB. Is that a big deal? are there any adverse side effects to adding an RSB?
Cheers!
Cheers!
Originally posted by darksands
Of all the suspention mods, its got to be the RSB that makes the most noticible difference. The back becomes really stiff.
Cheers!
Cheers!
And people that hear popping noises with their RSB put them on wrong. I heard no popping when I put on my RSB. There are no real adverse side effects to adding a RSB.
Here's my opinion. I had the Addco RSB on my car when it was the stock height and then when I had my Suspension Techniques springs (1.6" front, 1.4" rear). The difference in handling was huge. The car was far more stable and I only had the bar adjusted to about 50% stiffness. Then I got Intrax springs (full 2" drop front/rear). With this drop, my roll center was much lower. With as little wheel travel as I've got in the rear, the RSB really doesn't serve a huge purpose. I experimented and took off the RSB. I didn't notice any real difference in handling. I did notice a better ride though because I reduced the rear beams unsprung weight by 15lbs. I ended up selling the RSB.
IMO, if you have the stock height or a normal drop (1.4-1.6"), get the RSB. It helps and you'll notice the difference. If you've got a 2" drop or coilovers, I don't think the RSB will do much for you other than cause a little suspension bind and a harsher ride. The lower you go, the harsher the ride. Some guys really like the super stiff, harsh ride, and absolutely flat cornering. Remember this though, super flat cornering doesn't necessarily mean better handling. Sometimes a little roll is good. Ironically, when Motor Trend tested the Stillen SC Max, they recorded better lap times and higher MPHs WITHOUT the RSB installed. The 4th/5th gen does have a RSB stock and it's HUGE (1.5" diamater). It's located inside the beam (you can see it from underneath the beam). How it works is that it makes the beam into the RSB by tying into the lateral control arms.
Dave
Dave
MaxStock
Aug 14, 2015 10:03 PM
