air vents wont shut off
Old May 23, 2002 | 06:59 PM
greenmax's Avatar
I just had a sound system put in my car and now when iam driving air is coming thru the vents.My climate control is off but there is air rather i leave the setting on cold or heat that what it blows out.What do you guys thing that wrong the dealer look at it and did not find anything.Thanks for the info
Old May 23, 2002 | 07:00 PM
greenmax's Avatar
Re: air vents wont shut off
It wasnt doing it before the system only afterwards
Old May 23, 2002 | 07:12 PM
lefty
Funny, my max does the same. If I turn off the climate control, what ever setting I leave it at is what the air blows out.
Old May 23, 2002 | 08:29 PM
njmaxseltd's Avatar
I have Auto Climate control, some air blows out the bottom at room temp when I shut mine off. I think cars are required to have fresh air into the cabin.
Old May 23, 2002 | 10:11 PM
Confused's Avatar
Permanent Maxima.org Resident
try pushing the button that indicates recirculating cabin air only.
Old May 23, 2002 | 10:31 PM
97GLE's Avatar
When you turn off the Auto Climate Control, the outside air vent opens and it swiches the vents to feet. Wind and your car moving push air through. Because your vents/condenser/heater core are still hot/cold the air that comes out will be hot or cold for a little while.
I'm not sure if this is what your experiencing, but my car has always done this. I dont think its something to worry about.
Old May 24, 2002 | 12:37 AM
joaquink's Avatar
¿Hablas Español?
BINGO! I had the same concern when my Max was new. I went to the
dealer and they said in order to close the system you have to turn
on recirculation. Worked perfectly and now no more cold air on my
feet. I think it's even in the owner's manual if I remember
correctly.
Cheers!
Old May 24, 2002 | 04:08 AM
greenmax's Avatar
I will try this
Old May 24, 2002 | 05:54 AM
sinewave's Avatar
When all else fails, RTFM.
Old May 24, 2002 | 06:01 AM
97GLES's Avatar
my car does the same. try it with your sunroof on tilt with windows closed. you will feel it more. the faster you go the more you get.
Old May 24, 2002 | 06:36 AM
Gary95's Avatar
When your climate control system is off, you can still press the recycle button (the LED will illuminate). No air should be passing through at that point.
tarun900
19
Dec 20, 2021 06:57 PM
Miket2006
Mar 1, 2021 03:55 AM
hayne
Oct 5, 2015 11:53 AM
Justin Kroll
Oct 1, 2015 07:03 PM
MichMaxFan
Sep 30, 2015 09:18 AM
