got new rotors and pads installed...break in period?
Old May 25, 2002 | 01:43 PM
Cumalot's Avatar
Today I got my Brembo cross drilled/slotted rotors and Raybestos Quiet Stop brake pads installed with the help of JAY25. Thanks a lot Jaime! Only the front was done.
Now what's the break in period for the rotors and pads? Jaime told me to take it easy for awhile. I tried, but I had to test the rotors and pads out when I was going home because of some crazy drivers. Anyway, when I came home, I noticed there was steam/smoke coming out from the rotors/pads. This is because they're brand new right?
Old May 25, 2002 | 02:48 PM
iwannabmw's Avatar
Re: got new rotors and pads installed...break in period?
I usually do 2-3 medium effort stops from 45 mph and then let the brakes cool for a while just driving. Then I do 2-3 medium to hard stops from 60 mph and then just drive for a while to let them cool. They will smoke a little after the second or 3rd stop. This is normal for the bedding in process and not a big deal, just let the brakes cool off slowly and do not keep your foot on the pedal when they are smoking after you stop, that could warp your new rotors.
Old May 25, 2002 | 04:09 PM
Cumalot's Avatar
Re: Re: got new rotors and pads installed...break in period?
Thanks, good to hear.
Old May 25, 2002 | 09:15 PM
MaximaPower's Avatar
saw u on the expressway earlier today around 11:30 headed down
terry parkway exit...thought u were going to see jaime
anyway, how much were ur rotors?
Old May 25, 2002 | 09:51 PM
phatmax95's Avatar
how much? thats really what i wanted, my pads are out, and my rotors are pretty warped, so i figure its a good time to upgrade
Old May 25, 2002 | 10:06 PM
Cumalot's Avatar
Really? Were you in your Maxima? I don't remember seeing your car. I bought the rotors for $165 shipped from a member that's selling his car. I bought the pads from PepBoys, forgot the amount.
DrivinDaMax98: see above for price. I bought them because my passenger side rotor was warped. I needed new rotors, so I thought I might as well get some good ones instead of the OEM ones. I'll get them for the rear too later on.
Btw, I noticed much better braking with the rotors. Also, the Quiet Stop brake pads seem to be pretty good too. There was a slight noise from the pads, maybe because they're brand new. I didn't put any of the anti-squeal on them though. I'll update on how these rotors and pads are after some break in period.
Old May 25, 2002 | 10:19 PM
phatmax95's Avatar
How much new? Sounds like a good price to me. How does the price compare to nissan rotors? Do any kind of pads brake at the same distance, and the rotors are what matters?
Old May 25, 2002 | 10:24 PM
Cumalot's Avatar
I'm not sure how much the rotors go for elsewhere. Nissan rotors should be a bit cheaper I think.
Old May 26, 2002 | 12:29 PM
i was with my dad in his safari van
i think i'll be needing new rotors too
how can you tell if the rotors are warped?? jus by looking?
cus my passenger front makes a scatching noise when i drive
slowly like in a paring lot...i dont know if anyhting is wrong
with it...it also gets hotter than any of the other rotors
Old May 26, 2002 | 01:14 PM
JAY25's Avatar
Michael is the brake man now so if you need help he can help you since Ill be gone. I was by terryparkway yesterday as well, about 930Pm and about 455am today.
Old May 26, 2002 | 04:37 PM
iwannabmw's Avatar
Warped rotors show up as a pulse or vibration when the brakes are applied. It sounds lie your's aren't releasing all the way on that side, so they are still engaged a little. That would account for the scratching sounds and the extra heat on that side. The caliper is probably binding on it's pins and not traveling freely or the piston itself is catching, which would necessitate a replacement or rebuild of the caliper. I'd take it apart and regrease the pins and see if that helps. If not rebuild or replace it.
Old May 26, 2002 | 04:41 PM
iwannabmw's Avatar
The compound of the pad is way more critical to the actual stopping power of the car than the rotor is. The slotted or cross drilled rotors will cool better so you'll be more fade resistant, but this only comes into play under extreme conditions.
I run cheapo Autozone blanks on mine with good pads and the car will stop on a dime. Since you probably won't replace them as often as I do, I would just get a high quality blank rotor or if you like the looks, slotted, but the slotted really isn't necessary for street driving. I'd spend the money on a good pad instead.
Apr 16, 2020 05:15 AM
NmexMAX
May 23, 2016 07:38 PM
Derrick2k2SE
Nov 19, 2015 10:14 PM
Socalstillen
Sep 26, 2015 12:01 PM
A32goldylocks
Sep 2, 2015 06:39 AM
