Rear Brake clunk and squeal from A/C compressor
Old May 25, 2002 | 07:00 PM
Shannon and Ian's Avatar
When we had the alternator replaced we get a squeal at start up from the AC compressor (I think).
Also when we first bought our 97 used we had a rear brake clunk. The dealer replaced the struts and other suspension parts. Still at low speed you get this clank, like the pads are too small for the caliper or something. They lubed the back of the pads with anti-seize (like I would not notice it) but it eventually came back. Do the rear brakes come with shims and maybe they are missing or should I look somewhere else?
Old May 25, 2002 | 09:34 PM
sbslacker's Avatar
Re: Rear Brake clunk and squeal from A/C compressor
Check the belts. Are they in good condition? Any tears or anything? Are they tensioned to spec? Are they the right size (long shot)?
Brake clunk....hmmm....you say you had some suspension 'parts' replaced but you are hearing a noise from the rear brakes? Are you sure the noise is coming from the caliper/pad/rotor area? All I can say is to take the brake pads out and check to make sure they have been installed correctly. The anti-squeal (anti-sieze is for plugs, bolts, etc...) goo goes on the back of the shim. Are the shims in good shape? There are anti-rattle springs that go in there too, make sure they aren't busted or otherwise.
If the suspension is making noise, then maybe the bolts need to be tightened or maybe there is a bushing or something missing.
I hope this helps...I know it is all sort of non-specific, but I'm just throwing things out there for you.
Old May 25, 2002 | 11:37 PM
Nismo's Avatar
Re: Re: Rear Brake clunk and squeal from A/C compressor
might also want to check the compressor bearing but the bearing noise would be quieter when the ac is turned on but who knows.....
Old May 26, 2002 | 07:08 AM
Definately the belt cause when I sprayred the belt with white lithium grease it squealed like hell.
Old May 26, 2002 | 11:03 AM
peteymax99's Avatar
You did a NO, NO. No grease on belt. Now you have to replace the belt for sure.
Matt93SE
May 24, 2019 02:58 PM
vingodine
45
May 21, 2016 12:46 PM
02PearlSE
Oct 7, 2015 02:12 AM
Huttig2009
Sep 25, 2015 03:31 PM
homeyclaus
Sep 3, 2015 06:15 PM
