pimpin aftermarket horn....install question.
Old May 27, 2002 | 11:06 AM
TooCold96's Avatar
i bought this looouuudddddd a$$ horn from this shop in chi-town but when i installed it i guess it work for a couple of horks but then it died. i wired it to the old horn by the windshield wiper fluid.i think a fuse blew but i couldn't find out which one.
i then tok the horn and wired it DIRECTLY to the battery..man big mistake..the horn worked but i went deaf for two days...forget about it. anyways what happend to the original horn why isnt it working now there isnt a fuse blown at least in the fuse compartement inside the ride.i guess the horn draws too much power.i'm out peace
Old May 27, 2002 | 11:14 AM
Ramius83
I don't remember, but isn't there a fuse in the engine compartment fuse box?....I would check that.
BTW, you have two horns on a 4th Gen, one in front of the radiator and one to the left of the engine. Disconnect both and try the other horn again, and replace the "blown" fuse with a stronger one.
Old May 27, 2002 | 04:09 PM
ericdwong's Avatar
Read the FAQ above and I answer which fuse probably blew when hooking up aftermarket horns.
Old May 27, 2002 | 05:31 PM
1MAX2NV's Avatar
You will need a relay and run your own wires. The new horns are drawing to much current.
bigdogsteve
Jan 31, 2018 04:18 PM
doctorpullit
Mar 29, 2016 11:08 AM
sliptap
Sep 30, 2015 05:57 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
