I Have 95K On My 97 (Highway) With No Leaks, Should I Swich To Amsoil?????
Old May 27, 2002 | 06:28 PM
FJC's Avatar
FJC
I am coming up on an oil change interval and just got the car. It runs perfect and does not leak. Think I'd be ok with Amsoil?
I actually used to work for Pennzoil and we refrained from using synthetic in anything over 70K, this was 7 years ago...
Since my car is relatively newer and runs fine, I should be ok???
Old May 27, 2002 | 06:31 PM
Gary95's Avatar
Re: I Have 95K On My 97 (Highway) With No Leaks, Should I Swich To Amsoil?????
I've heard there is nothing wrong with switching. You may want to skip using any "cleansing" oils (I think they have some kind of treatment), because they could compromise your seals. I plan on switching in July...
Old May 27, 2002 | 07:57 PM
TurDz's Avatar
when's the right time to switch to synthetic? my red max has 60k miles. is that far enough?
Old May 27, 2002 | 09:35 PM
rmb's Avatar
rmb
You can switch to whatever synthetic you want whenever you want. It's stupid old fairy tale that you have to wait xxxx miles for the engine to break in. Porche's and corvettes come stock with Mobil 1 so I wouldn't worry about it.
The old problem of sythetic not "swelling the seals" is also largely BS.
Use the same viscosity and you'll be fine.
-RMB
Old May 27, 2002 | 10:14 PM
TurDz's Avatar
Re: Re: I Have 95K On My 97 (Highway) With No Leaks, Should I Swich To Amsoil?????
-RMB
thanks for the enlightening info. but why do people use viscosity other than 5w30?
Old May 27, 2002 | 10:29 PM
xHypex's Avatar
Re: Re: Re: I Have 95K On My 97 (Highway) With No Leaks, Should I Swich To Amsoil?????
Mostly due to temperature variations. I live in Texas, so I'm running Amsoil 10W30 because of the heat. In colder areas you may find people running 0W30, but most still run 5W30.
-hype
Miket2006
Mar 1, 2021 03:55 AM
mclasser
22
Nov 12, 2020 01:58 PM
uttadms31
Sep 30, 2015 05:24 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
