Car not starting.
Old May 28, 2002 | 06:49 PM
SuDZ's Avatar
Car not starting.
Alright guys lets see if any of you have an idea whats going on. Here is the problem.
Tonight I was at the hospital and whn I came out my car wasnt starting. The battery is fine and all accesories work. Yes there is gas. The plugs are platinum and only about 10K old at most. The fuel filter is new, oil filter etc is fine and new (nissan brand). Cone filter is clean sop everything seems like it should be okay as far as tuneup type things go. Also I checked the plugs to make sure the engine wasnt flooded or anything or had gas in there.
It would sound like it was just about to kick over but not actually turn on. It sounds like it is so close to kicking on but just wont. I dont know whats happening or why it isnt coming all the wa over. Any ideas? I am looking for anything at this point since it is still there. Could it be a starter? I figured if it was it would have given warning sounds though like squels on the startup and things like that I heard before.
Any help is great.
SuDZ
Old May 28, 2002 | 06:54 PM
4GRookie's Avatar
Not sure if it helps any but my dad had the same symptoms on his Accord. We had the started tested at AutoZone and they said it was good. Since they said it was good...my dad was puzzled since he checked everything else like you did, and decided to take it to the dealer since he needs the car to go to work. We had to get it towed to the dealer and to our surprise it was the damn starter.
Old May 28, 2002 | 07:52 PM
pro's Avatar
pro
It's propably the starter.
Thanks,
Paul
Old May 28, 2002 | 09:00 PM
SuDZ's Avatar
Yeah I think tommorow I may check out the starter issue. It will be better during the day to work on it. Is there a way to test the starter?
SuDZ
Old May 29, 2002 | 07:51 PM
cmac95gxe's Avatar
Maximaniac
SuDZ
Good luck
Old May 29, 2002 | 09:27 PM
TheNip73's Avatar
Could be the Ignition Coils? Or am I on crack. I'm not sure if thats the name of the part.
Old May 29, 2002 | 10:43 PM
VeeQueue's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
SuDZ
Have someone crank the motor while you try smacking it with an end of a stick (no, I'm not joking).
Old May 29, 2002 | 10:44 PM
MIXXMAX's Avatar
I can probably guarantee it's the starter. Our Maximas are proned to have bad starters. If it fails to start, do what I do, "joggle" the key in the ignition while starting....this will get the solenoid going, because the solenoid tends to get stuck. Or, if that doesn't work, have someone tap on the starter while cranking. This helps also. Believe me, I had my Max for almost 8 years now, and I have experienced everything with starting problems. In fact, mine "acted-up" today. The starter is fairly new, not even a year old. I knew I should have bought a 10 tooth, instead of the regular stock 8 tooth gear!
Old May 29, 2002 | 10:48 PM
VeeQueue's Avatar
I had a similar incident with Autozone. The alternator caused the battery light in my folks' Accord to light up. It was on its way to crap out but Autozone's cheapo diagnostic equipment kept saying otherwise. I replaced the alternator and the battery light went out.
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Balkins
Aug 12, 2015 06:39 AM
altome15
Aug 10, 2015 07:05 PM
