Spark Plugs
Old Dec 1, 2000 | 09:31 PM
Nick Robinson's Avatar
So those 5 dollar apeace spark plugs taht you see at VIP or your local car store... you know, bosch or somthing like that. Do they really do anything? Like add HP? If so, why the hell havnt i done that yet?!
Old Dec 1, 2000 | 09:41 PM
emax02's Avatar
The only plug that I have ever seen,
add HP on the Dyno is Denso Iridium which cost about $15 a piece,I have them and like them.
Old Dec 1, 2000 | 11:46 PM
Maxima97GLE's Avatar
those bosch platinum 4's any good?
Old Dec 1, 2000 | 11:53 PM
emax02's Avatar
I have heard many complaints with the Bosch+4,
plugs causing power losses,also about 2 years ago consumer reports did a review on them and did not recommend them for any application.I would either go with NGK platinum OEM plugs or my favorite choice Denso Iridium.
Old Dec 2, 2000 | 03:27 AM
Eric L.'s Avatar
Most people here like the stock spark plugs...NGK Platinums.
Normal Nissan dealer will charge you like $20/piece. But Courtesy or Carparts.com charges like $7-8 per plug.
Old Dec 2, 2000 | 05:19 AM
96BLUMAX's Avatar
how much of a gain in hp?
Old Dec 2, 2000 | 06:29 AM
Good thing i didnt buy the bosch
Yay! I love this board. Hehe. So do i want to spend 120 bucks on spark plugs and get those 20 buck a piece ones. Is it going to add that much?
Thanks guys!
Old Dec 2, 2000 | 11:30 AM
emax02's Avatar
In a old car tuner Mag,
they replaced a NA Honda Civic with OEM plugs and Dyno'd it and then replaced the new OEM plugs with the Denso Iridium plugs and gained 2.3HP on the top and even more in the Midrange.Also they tested a Sykline or something that had like 28PSI pumping in the engine from the turbo's and they used the the Denso Plugs and gained like 28HP, but don't expect more then 3-4HP from the plugs unless you are using some sort of forced induction.
Old Dec 2, 2000 | 12:27 PM
96BLUMAX's Avatar
How hard is it to change the plugs? Cause i think i might get the densos cause soon i will run out of things to do to my max except a supercharger.
Old Dec 2, 2000 | 02:57 PM
PodiumPaul's Avatar
Bosh Platinum plugs cause a rough idle in any Maxima. Stick with the NGK Platinum.
Old Dec 2, 2000 | 05:31 PM
SmoothMax's Avatar
OG
I'm gonna have to say stay with stock. The minds over at Nissan knew what they were doing when they put the NGK's in the Max to begin with. The Iridium plugs may give you 2.3hp or something like that, but it's not gonna be a "tires spinning off the line" difference. You might not even feel it at all. I say stick with the oem plugs and save some dough IMO.
magiconthetire
Oct 26, 2015 09:03 PM
Need help
23
Oct 2, 2015 08:56 AM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
