ticking noise... WTF
Old May 30, 2002 | 07:08 PM
JMAXIMA's Avatar
a few days ago i lifted my hood and heard this ticking noise... it was coming from around my TB... but i can't exactly locate it. now today while i was changing my coolant, it was a bit louder, but it sounds like it is slightly backfiring in between ticks. they only happen @ idle... w/o a/c... and if i rev it a small amount... it goes away for about 30 seconds... then returns... and the sound is about 1 second apart... any ideas????
Old May 30, 2002 | 07:15 PM
mzmtg's Avatar
Minister of Silly Walks
IAC and/or EGR
Old May 30, 2002 | 07:20 PM
JMAXIMA's Avatar
Originally posted by mzmtg
IAC and/or EGR
either one harmful to leave alone or expensive to replace?
Old May 30, 2002 | 07:25 PM
mzmtg's Avatar
You can try cleaning them both. But neither one will cause problems. Try doing the regular diagnostics according to the Haynes Manual.
Old May 30, 2002 | 07:31 PM
Ramius83
On a side note, is your A/C on....it MAY be the compressor....
JMAXIMA's Avatar
thnx
Old May 30, 2002 | 07:35 PM
JMAXIMA's Avatar
actually, it goes away with the ac on... if the RPM's are any higher than normal idle, the noise is not there... and like i said, if i rev it up even a small amount, it goes away for a bit... but i do know what compressor noise you are talking about... my makes a some noise... nothing too bad though
Old May 30, 2002 | 07:38 PM
JMAXIMA's Avatar
damn... that sounded retarded... mine makes some noise... there.. that sounds a little better
ColdCananda
Sep 20, 2015 10:45 PM
Quickgtp
Aug 27, 2015 02:13 PM
vanebecker
Aug 17, 2015 08:24 PM
