Injen vs. PR
Originally posted by SLC I30t
plenum
plenum
Toyota and honda usually don't put 14 inch intake runners on their engines either. No flame... I promise.
Dave
Originally posted by Dave B
The Celica GT-S has 12" runners and the B18C5 has 10" runners. Visually, the runners don't look as long on the 4-bangers because the runners are usually curved and not straight like the VQs.
Dave
Dave
Originally posted by SPQQN
Just baught a Injen intake from SWA for $240 and glad i did, i am not going to cut no hole in my new used maxima
Anyone ever notice???
On my 98 Maxima, when I was installing the PR CAI, there was already a 3-3.5" circular pattern etched in the metal, apparently from the factory. It was as if Nissan was going to use it for the intake, but decided not to.
DW
DW
Originally posted by JAIMECBR900
Again, do you know where the hole WOULD be if you did cut it? I doubt it, cause if you did, you wouldn't worry about. It is covered up by battery tray, fuse box, and stock airbox (should you go back to that). It is only noticeable if you are looking for it.
Re: Re: Injen vs. PR
Originally posted by BenBlanco218
Injen makes one for Maximas? Either way, the Place Racing upper pipe and pop-charger intake (Stillen or JWT) happen to be the most beneficial all around, unless you happen to not have oem fog lights, the complete Place Racing cold air intake is just as good, but I herad longer tubing sacrifices the top end.
Y2KevSE
72
Aug 4, 2008 08:21 PM
ajaffee
Mar 15, 2001 11:20 AM
