Transmission buzzing
I recently purchased a 99 SE-Limited with an automatic transmission. I have noticed a slight buzzing sound at the front of the engine. Through further investigation, the buzzing sound is coming from the transmission. I can place my hand against the transmission pan and you can feel it vibrating inside. I can only assume this is where the valve body is. What would cause this buzzing and how do I fix it? I have noticed that when I press the accelerator pedal about an inch or two that the buzzing just about goes away. As soon as I let the pedal back up the buzzing becomes more noticeable. Any ideas or suggestions?
I agree.
Ninos_Maxima and I encountered this problem on his 99 GLE when we got done putting his stock plenum and stuff back after he changed his mind on 00vi. Problem turned out to be a disconnected ECU that Mr Duck disconnected while assisting him with the 00vi days prior to that.
Hope that kind of helps.
06-06-2017 02:01 PM
Pied
09-26-2015 03:29 PM
