tried to brighten clearance lights...didnt work...ideas?
Old Jun 6, 2002 | 08:36 PM
gepetto's Avatar
this is kinda of a continuation of another thread, but today i opened up my clearance housing and got the bulb out, clipped off the little nub closest to the glass. i put it back in. one way it felt loose, and only worked when the signal was on. the other way it felt tighter and worked normally (i have a 95). any ideas what i did wrong? any suggestions would be appreciated.
Old Jun 6, 2002 | 08:57 PM
Michael J.'s Avatar
I think it's because you have a 95. NOt exactly sure but I only think this works with 97+ since 97+'s don't get brighter when you turn the turn signals on. Hope this helps a little.
- Michael J.
Old Jun 6, 2002 | 10:12 PM
ladeesman's Avatar
No works for the 95 because I've done it. Shave both nubs completely and totally reverse the position, 180 turn. That should extremely increase the brightness.
Old Jun 6, 2002 | 11:39 PM
95emeraldgxe's Avatar
try to rewire them??
Old Jun 7, 2002 | 02:08 AM
max808's Avatar
if you shave both nubs there won't be anything holding the bulb in harness? are you talking about the same bulb? 1157?
Old Jun 7, 2002 | 03:03 AM
TurDz's Avatar
I'm very experienced with this. I've gone through about 10 bulbs, just testing them out and what not.
The best way to do the shave-nib mod is to shave the top nib, and here's the catch: cut a 2 inch strip of electrical tape about 1/4'' tall, and wrap it on the level of the base that you just nibbed off.
This creates a very tight and secure fit, and I've found that its been a guaranteed success every time I've followed this procedure.
hope that helps
Old Jun 7, 2002 | 06:56 AM
gepetto's Avatar
so when i try it next again today, just cover the cut off nub with electrical tape so that it gets a secure fit? thanks...
Old Jun 7, 2002 | 09:28 AM
ladeesman's Avatar
I simply shaved both of mine and pushed it in already turned 180. Not put it in normal and then turn it. It works and stayin quite snugly.
Old Jun 7, 2002 | 09:31 AM
Ginuwin3112
The bottom of the bulb has two little nipples right, while only one contact on the socket has power to it..what i did was lay about 1x1cm piece of aluminum foil between the socket and bulb. now both elements light up and no problems.
Old Jun 7, 2002 | 01:17 PM
gepetto's Avatar
success!
well i used the electrical tape method today and it worked perfectly on both sides. thanks for all the help you guys.
my first official "mod"
the FSTB arrives today
Old Jun 7, 2002 | 01:30 PM
max808's Avatar
Re: success!
good job, i just cut the upper nub off with a nailclipper and inserted it backwards. i didn't use the tape method but it's good to know that also works too.
Old Jan 7, 2003 | 08:47 AM
amb4081's Avatar
Re: Re: success!
If you put it in backwards, how are the connections at the bottom going to be made? If you reverse the bulb and the bottom nub is in the upper slot, how will the bulb set deep enough in the socket to make contact? I tried it that way and got ZERO power to the bulb. What am I doing wrong?
lowpost99
Oct 26, 2025 06:53 PM
schmellyfart
Sep 25, 2015 04:47 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
RealityCheck
Aug 5, 2015 06:18 AM
djhooker
Apr 1, 2001 09:13 PM
