Help !! head lights work but nothing else no running lights no tails ....
Old Jun 7, 2002 | 12:44 PM
madmax97's Avatar
only my headlights work notthe ones next to or below and my tails dont work either but do work when brake is applied ...what to do was is it?
Old Jun 7, 2002 | 10:41 PM
SYCEFIRO's Avatar
Re: Help !! head lights work but nothing else no running lights no tails ....
IT's just a fuse blown...
check in the fuse box.. under the your pwr mirror switch..
change a fuse.. it will work
SY~
Old Jun 8, 2002 | 07:27 AM
ny96max's Avatar
sounds like an AUX Electrical fuse, 7.5amp to be exact should be at the top of the fuse panel.
Ant
Old Jun 8, 2002 | 11:53 AM
Ramius83
Also, check the fuse box right behind your battery. There is a fuse on the right side near the top that controls lighting. Mine always blows for some reason.
Old Jun 8, 2002 | 12:17 PM
xHypex's Avatar
Sounds like the Tail fuse to me. It's a 7.5A fuse that runs your front corner lights as well as the corner lights in the tails. Are you corners rewired? I blew my fuse and a bulb on two separate occasions when I was running rewired Polargs in the corners. Since then I have switched back to stock bulbs with no problems.
-hype
jerrod99_se-l
Aug 27, 2015 08:27 PM
spidgeon
Aug 18, 2015 05:46 AM
doobadoo
Aug 15, 2015 06:43 PM
Samedi
Aug 13, 2015 04:05 PM
kenc15
Aug 5, 2015 08:29 AM
