1/4 mile dilems with times
Old Jun 8, 2002 | 03:51 PM
SLC I30t's Avatar
question here
I had 60ft times of 1.7 and 2.0 and 2.1 in the 50ft and around 6.1-6.2 in the 300ft. But my ET was 15.1 and around 91 mph. Will a B pipe help even out these times? People told me that with 60ft times like these I should be well into the 14's.
here are my times per pass
60ft 330 ft 1/8 1k 1/4@mph
2.3562 6.5608 10.0313 12.9972 15.4981@90.7046 5:36pm
1.7222 6.5354 9.9970 12.9493 15.4472@90.8269 5:53pm
2.0667 6.5243 9.9727 12.9193 15.4660@85.5773 5:59pm
2.3394 6.4794 9.9048 12.8396 15.3236@91.0861 6:16pm
2.2977 6.3902 9.7993 12.7093 15.1781@91.6868 7:41pm
2.2993 6.4364 9.8689 12.8039 15.2890@91.0083 8:32pm
2.2716 6.3640 9.7841 12.7136 15.1985@91.0564 10:06pm
Old Jun 8, 2002 | 05:11 PM
Nealoc187's Avatar
SLOW
Re: 1/4 mile dilems with times
Originally posted by SLC I30t
question here
Are you running slicks? If not, that 1.72 60' time is a timing messup, as is that 2.06 unless you are God. A 2.06 MIGHT be possible, the closest I've ever seen is a 2.09, and I've only seen that once (from a Maxima).
To illustrate my point, if I had pulled a 1.7 60' time when I was bone stock, I would have run at or around a 14.0 (14.8 @ 92.6 with a 2.21 60' is what I actually ran).
Honestly I think something was wrong with the timing equipment.
Old Jun 8, 2002 | 05:45 PM
SLC I30t's Avatar
Re: Re: 1/4 mile dilems with times
I was running with 14psi on kumho tires. I was racing a Vette on that same heat and he got a 1.9 I remember both of us popping out at the same time and being a head a little bit. But I don't know for sure. I also tried the shallow stagging technique, so maybe that could've helped me a little. But you are probably right about the timing being off. But isn't all of that automated?
Old Jun 8, 2002 | 05:48 PM
Toolrocks's Avatar
Yeah Louie,
Going w/ what Nealoc said, I looked at my time slips from Capitol and it does make sense, when you compare all the numbers, that the 60 foots are wrong. Look at your other slips from other nights and you'll see that your 1/8 miles are off considering your 60 foot times. Your 1/8 times look consistent w/ 2.35s or higher 60 foots.
Old Jun 8, 2002 | 05:50 PM
SLC I30t's Avatar
Originally posted by Toolrocks
Yeah Louie,
Understood. I went back and looked at the other times for people in that same lane. All the 60ft were off. I fell better knowing that my car is just slow, not all f-ked up.
CorollaULEV
30
Aug 9, 2021 08:11 PM
Matt93SE
May 24, 2019 02:58 PM
MatthewsMaxima
Sep 11, 2015 03:21 AM
Maxgig
Aug 18, 2015 09:17 PM
yat70458
Aug 3, 2015 01:16 PM
