Making horn beep with factory alarm
Old Jun 10, 2002 | 06:34 PM
69CHARGER_RT's Avatar
Has anyone been sucessful in modifying their factory alarm to make the horn toot when setting it?
I hate having to wait to see the signals flash to know the doors have locked and the alarm has set.......
Thanks in advance!
Old Jun 10, 2002 | 06:43 PM
BBaker025's Avatar
This topic has been tossed around for a long time. The closest thing anyone has done is for $10 you can make it chirp. If you had searched then you might had found the answer!
Old Jun 10, 2002 | 06:56 PM
matty's Avatar
Can sombody post the HOW-TO ???
thanks...the search button is broken
Old Jun 10, 2002 | 07:03 PM
BBaker025's Avatar
Here is the link on how to make your Horn Chirp!
Old Jun 11, 2002 | 05:22 AM
Thanks for the info guys............
Remember the search feature
remember the search feature
remember the search feature...........
Old Jun 11, 2002 | 08:13 AM
I just did the upgrade. My local RS didnt have the buzzer so I used a 102db siren.
Works pretty cool. Doesnt beep, kinda goes woo woo......woo woo
High pitch .......
Not too bad. easy enough to change if I want to
Thanks again!
Old Jun 12, 2002 | 09:10 AM
ladeesman's Avatar
I don't exactly understand the diagram of how to wire it to the new relay, can someone explain? There are like 5 prongs, which do i wire it to?
Old Jun 12, 2002 | 11:08 AM
jayanth's Avatar
I did this mod 2 weeks ago and was a complete success.I bought a two tone beeper and it works cool.It cost me $24 but it's worth it.I hear a high pitch tone and a low pitch tone when i lock my max.
take care,
Jay
Old Jun 13, 2002 | 10:13 PM
ladeesman's Avatar
ok well i really wanna do his but um dunno how, can i get some help on the relay?
Old Jun 14, 2002 | 01:13 AM
02SM520's Avatar
Same stuff have been talking about for Samsung SM5 too..
It is really good idea. Sometimes I press the lock button on
the remote little longer so panic mode starts.. YUK..
After the modification 2002 SM520 will beep twice when doors
are locked and beep once when it unlocks.
But 2001 and older model of SM520 will beep twice when doors
are locked and no beep when it unlocks. Just like Maxima....
Yuk.. Mine is 2001 SM520 so I will have beep only when doors
are lock.
Old Jun 14, 2002 | 04:01 AM
I didnt use the relay that the article suggested. I used a standard Bosch 12v relay.
If the relay has markings or #'s on each terminal (most should) heres how I wired mine.......
Term # 86---------green/orange stripe (12v+)
#85-------------orange (BCM)
#30-------------green/orange stripe (same as #86)
#87-----------goes to + of buzzer
Hope this helps
Old Jun 14, 2002 | 09:38 AM
ladeesman's Avatar
Ok the diagram on th back of the package shows 2 termials connected by a coil. Then one the is NC and 1 that is NO, those teo show connections to a third one. If I do this wrong will it go bad?
MR2 T'd
Jul 9, 2021 05:06 AM
MaxLife17
Jun 27, 2019 01:37 PM
Vistance
Sep 17, 2015 05:17 AM
MaxLife17
Sep 8, 2015 02:36 PM
Pnjboyzz
Sep 4, 2015 09:04 AM
