1/4 Mile Time
I'm running my car this weekend. THe temp should be mid 70's, elevation ~500ft. The track is in good condition. What should I run with this setup:
97 Max SE 5Spd ~45K miles
Cone Intake
Cattman Ypipe
Greddy Catback
Yoko A520 225/50/16
Eibach / Tokico
I shift pretty quick. Also, what PSI should I run the fronts and what RPM should I launch? Right now it's VERY easy for me to spin all of first.
Cone Intake
Cattman Ypipe
Greddy Catback
Yoko A520 225/50/16
Eibach / Tokico
I would say between 14.6-14.9,
It all depends on your driving ability and if you gut your car or not,about tire pressure pump your rears up all the way to 44PSI,and fronts I am not positive but about 22 PSI.For the lonch try reving youre car up to 4K RPM'S and don't just dump the Clutch rather release it just far enough so there is very little or no peel out.Pracice makes perfect Good Luck
Pretty hard to predict, but 14.8-15.1 seems reasonable-->
Cone Intake
Cattman Ypipe
Greddy Catback
Yoko A520 225/50/16
Eibach / Tokico
Cone Intake
Cattman Ypipe
Greddy Catback
Yoko A520 225/50/16
Eibach / Tokico
Practice does make a difference. I got the Gtech time too to help. That way if my 0-60 sucked I wouldn't bother running the 1/4
My 14.9x were all run at normal 34/31 tire pressures with some spin. You've got the Catback - I've got the UDP and RT Cat; pretty similar times probably. Good luck!
P.S. Brian's a pretty cool name!
I dunno I think that one guy thinks I just have the YPipe, but I got Intake and Catback. I don't think a 14.9x is unreasonable? I've raced my integra before, but this will be a first for the Maxima.
Cone Intake
Cattman Ypipe
Greddy Catback
Yoko A520 225/50/16
Eibach / Tokico
Cone Intake
Cattman Ypipe
Greddy Catback
Yoko A520 225/50/16
Eibach / Tokico
First time out you'll probably be in the 15.3-15.6 range. I too thought I was a good driver in my Maxima until I raced it the first time. I ran 3 times and ran a 15.5, 15.6, and a 15.5 all runs with 2.5 60 foots. All runs were in the 91mph range. I made a lot of newbie mistakes though. I was running my heavy 17s, high pressure in the tires, full tank of gas, no cool down, no ice, and 90 degree weather. Next time at the track I break into the 14s and run a 14.99@92mph with a 2.4 60 foot. The last time out at the track I was 14.91@94mph with 2.4 60 foots. My shifting got better and my mph went up dramatically. My 60 foots are just pitiful.
Don't expect 14s your first time out because the track is much slicker than the street. Just do the best you can. 14s are easily possible, but it takes lots of practice.
Dave
Dave
We all think we're good drivers until you get that timeslip and look down and see mid 15s and you've got all the power mods. I was really disappoiinted my first time out, but I kept practicing. I love how my mphs are really high (94-96mph), but my ets still really suck. I still haven't found the right way to lauunch this car.
Dave
Dave
CorollaULEV
30
Aug 9, 2021 08:11 PM
MatthewsMaxima
Sep 11, 2015 03:21 AM
yat70458
Aug 3, 2015 01:16 PM
