Don's site is down, anyone have the VB Mod install instructions?
![](https://maxima.org/forums/images/smilies/support.gif)
Don's site is down,anyone have the VB Mod Install instructions?
I'm doing it tonight, and would like to print the instructions out one the color printer at work right now.
Thanks!
IanS
Thanks!
IanS
Go to the How2 section of http://www.maximadriver.com/ ,scroll down and you'll see the link to the VB install docs.
I couldn't fix your brakes, so I made your horn louder
it links 2 don's site...... so this is no good.
![Wink](https://maxima.org/forums/images/smilies/wink.gif)
Btw Ian, it took me 4 hours to replace and install the VB mod without anybody's help.
Note:
In the Step 1 document you'll see a diagram with the hand holding the stopper ring. I found out afterwards that if you tilt the picture over so that the words "Figure 1" is on the right hand side that will be a true picture of how the harness is located when you peer down into the engine bay.
Note:
I just tried it and it works.
Re: Don's site is down, anyone have the VB Mod install instructions?
Thanks!
IanS
Thanks!
IanS
Note how the linkage pin is positioned before taking out the vb.
When you finally take out the last bolt, lower the vb down very slowly and carefully. There is a spring that sits vertically on top. Note where that spring sits when you get to reinstalling the vb.
![Stick Out Tongue](https://maxima.org/forums/images/smilies/tongue.gif)
LOL Hindsight is 20/20...
In retrospec I can't believe that I had actually did the vb switch all by myself and with my limited mechanical skill.
I made one slight boo-boo and that was not installing the linkage pin properly. I had to guesstimate how it was supposed to line up because I didn't look at everything carefully.
I just did it methodically and extremely carefully. I even made a blowup of that bolt diagram and color keyed it so I could keep all of the bolts in the right places.
I still have one unused can of brake cleaner left over!
One last thing: Check the bag that Don shipped the vb mod in. Reason for that was after I had finished installing the vb I found this metallic "pill" in the bag. I was shocked and afraid that it fell out of the vb. After speaking with Don directly it was determined that it must have rolled off of his workbench and into the bag. Whew!
![EEK!](https://maxima.org/forums/images/smilies/eek.gif)
I've got theinstall going now (laptop in the garage)
I can't find the harness to remove that pin from in figure 1 to save my life.
Can anyone help me out here?
Is it up front by the radiotor/fans, is it in the back directly over the drain pan!?!?
I just don't see anything even similar to the picture, even with it turned so FIGURE 1 is on the right.
Got the pin out, VB is out, but need to ship to Don and his address is not on his site anywhere....looked for 30 minutes, also did a search on the org...no luck.
BlackCat, do you have it? Anyone?
IanS
IanS
Unless somebody here knows I'll dig up my documents when I get home.
Nevermind, I got it.
My next question is:
Whenremoving the oil pressure sender to put the T in, how do you get the sender off? Is it a deep socket ratchet I need? What size? I just tried a 22mm Deep Socket, and no dice. (too small)
Thanks,
IanS
Thanks,
IanS
dank4us
34
06-10-2024 03:45 AM
MaximaDrvr
08-19-2015 08:20 PM
kirkhilles
08-08-2015 10:53 AM
00 Max
08-04-2015 07:09 PM
