ypipe installed...got a ? on noise
Old Jun 15, 2002 | 04:14 PM
MaximaPower's Avatar
we installed wsp ypipe on my bro's 97 I30
when we took it for a ride i heard a weird noise
when my bro gave it some gas...like getting it up
to around 2500 rpm....the noise was coming from like right
under where the ecu is.....an air gushing noise (dont know
how to explain it)
r ypipes suppose have a sound?
BTW, my bro has greddy catback and JWT +upper tube
Old Jun 15, 2002 | 04:17 PM
Cumalot's Avatar
probably the infamous bees in the can sound. I thought the new WSP ypipe suppose to eliminate this sound though? I have a pretty weird sound on my WSP ypipe too. I replaced the old flex section with a new lined flex section, but there's still some odd noises coming from the ypipe itself.
Old Jun 15, 2002 | 04:21 PM
i dont think it's a bees in a can sound....doesn't sound like that
how do i know what the old flex and new flex section looks like?
Old Jun 15, 2002 | 04:51 PM
bad news
my bro jus called me and said his car vibrates like crazy
it wasn't like that earlier, well we're both tooo tired
to check it out....took us over 4hrs to install
Old Jun 15, 2002 | 05:36 PM
Cumalot's Avatar
If it's not the bees in the can sound, it might be similar to what I have now. Is it more like a buzzing sound? That's what my ypipe sounds like now.
Old Jun 15, 2002 | 06:10 PM
Toolrocks's Avatar
The rattling noise is caused from the hanger at the y pipe and cat convertor connection point. Get under the car again and bend the hanger in towards the pipe from both sides. My car had a similar sound that you described - it went away after I fixed my rattle. I thought it might have been; when accelerating hard your engine rocks a little. When it rocks it elongates the flex section. I thought that after elongating the flex that maybe it leaked a little? I never figured it out but it's gone away. Took about 2 months to go away.
One last thing; you did put new gaskets in at the two downpipe locations and at the cat ypipe connection right? Good luck.
Old Jun 15, 2002 | 10:55 PM
that's what i was thinking....when we put the hanger
back we weren't sure if we put it back the right way
either.....we'll have to check that soon
and yes we did put the new gaskets on all 3 ends
Mike: i think it's a buzzing sound...it's not very loud
either..but still noticeable
Old Jun 15, 2002 | 11:30 PM
Nismo's Avatar
I also have a weird sound but I think its normal.Its not really a buzzing but a very deep drone at any rpm under 3k and loudest around 1.5k. I checked everything and no leaks and also checked my flex which still looks fine inside it.
question- what does it sound like if theres a leak in the manifold/ flange? only thing I havent checked yet is the rear manifold area.
Old Jun 16, 2002 | 08:28 AM
NotNew!!NewSN!!'s Avatar
you said it was a air rushing sound, not a vibrating sound, the air rushing sound is common with all y pipes. Im guessing its due to the new air flow capabilities of the two straight pipes that go back, it has a sort of turbo wooshing sound to it, and that sound is very normal, everyone i know has it.
Old Jun 16, 2002 | 08:32 AM
maybe that' it....i've never really noticed it in other maxs
with ypipe...and i havent really been in too many other maxs
well that's great to hear that it's normal
thanks
user 11122324
42
Jul 18, 2022 03:35 PM
aw11power
Oct 10, 2021 04:57 AM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
