Did I FINALLY fix my car???
OK, I don't want to jinx anything, but I think my jerky/jumpy hesitation problem may have FINALLY been solved!!!
So, what I did BEFORE:
changed my knock sensor
changed my engine coolant temperature sensor
changed my pcv valve
changed my fuel filter
cleaned my throttle body
cleaned my IACV
NONE of these helped (mind you, its good for maintenance!)
So, finally what I did was tighten two of my ground wires -- along the fuel rail...and THINGS SEEM MUCH MUCH BETTER
so, the moral of the story, check your GROUND WIRES!!!!
Thanks to everyone for their $0.02...this has gone on so long,
I've got about $10,000 is advice!!!
FLO_BOY
cleaned my IACV
FLO_BOY
When does this "jerky/jumpy hesitation" happen? Is it when you're crawling in congested freeways in first gear or second gear and maintaining a constant speed which the tachometer indicates 2000 or so rpms? Mine exhibits this symptom around 2000 rpms on 1st or second gear. Also if I let go of my gas pedal around 2200 rpm I can see/feel/hear the rpms winding down in a lurchy fashion.
I went ahead and tightened those two ground screws you mentioned. Hopefully it helps the symptoms (are we talking about the same thing?).
Re: Did I FINALLY fix my car???
cleaned my IACV
FLO_BOY
cleaned my IACV
FLO_BOY
This is the news I've been waiting for! You've made reference to ground wires in your past posts...Can you elaborate on the ground wire tightening? Forgive my ignorance, but I don't know where the fuel rail is located. Thanks.
BTW...What do these ground wires belong to?
Re: Re: Did I FINALLY fix my car???
This really didn't provide much info, and everything looked great, so, I would
skip this step at first.
Second, I removed the ground wires located by the fuel rail...cleaned them thoroughly...
re-wrapped them in tape...and tightened them back to their original place.
Today, I experienced some more "jerky-ness", checked the bolt, and sure enough,
it wasn't that tight (I need new bolts, these aren't exactly right)...
OK, so, here's a pic of my engine bay (since cleaned!)
Engine Bay
In this pic, move about an inch to the right of the dipstick (yellow) and there
are two bright screws -- those are the ground wires...please make sure that
these are TIGHT!
These grounds are for (I think) the Knock sensor and that green sensor near the knock (for sure).
Hope this helps!!! Let me know if you have other questions.
best,
FLO_BOY
Originally posted by t0mt0mboy
flo_boy...so wat are we suppose to look at here...is it those wires that are exposed in the picture...can u show us on the pic...thanks
Ground Wires to check
Let me know if this helps...
FLO_BOY
Its kind of not really smooth at low speeds is it?
Lakersallday24
03-20-2024 11:22 AM
Lakersallday24
06-16-2019 01:35 AM
JMag90
08-25-2015 09:17 AM
kirkhilles
08-08-2015 10:53 AM
