lil shakin' and more when AC is on
Old Jun 16, 2002 | 05:29 PM
skiavgh's Avatar
Hey all, i just had a question of course. has anyone experianced a lil shaking in thier maxima's? I have a 98, and lately its been shaking on idle.. my friend say's its nothing, just harmonics in the engine and im too paranoid, and when AC is on it shakes more.. mabye I need new belts or they need to be tightened? Just a thought.. thanks guys!
Old Jun 16, 2002 | 06:30 PM
Jamsan's Avatar
make sure all your hoses and clamps are tight on your intake...make sure there are no leaks....clean out your throttle body second, and see if that solves the problem....if not, clean out your IAC valve (search on how to), and if that still doesnt solve it, check for any error codes...may be the knock sensor
Old Jun 16, 2002 | 08:02 PM
pocketrocket's Avatar
Re: lil shakin' and more when AC is on
skiavgh
If your idle is too low, it's bound to shake. Make sure the idle is where it should be.
Old Jun 16, 2002 | 08:23 PM
skiavgh's Avatar
Yeah, idle is where its always been.. around 5 and 4...
also, the name is Don nice to meet ya
Old Jun 16, 2002 | 08:36 PM
97GLE's Avatar
That sounds low to me, idle should be at least 600.
Old Jun 17, 2002 | 11:02 AM
njmaxseltd's Avatar
Thats to low. You should be at around 600.
Old Jun 17, 2002 | 11:11 AM
wope's Avatar
try cleaning your throttle body
Old Jun 17, 2002 | 12:41 PM
meccanoble's Avatar
Sports Button FTW
dam man, i just installed PR CAI a week ago and there are two hoses connected to transmission that are now disconnected and just chillin in the bay...and there is one sensor that is not connected cause i can't find where to connect it...the engine light is on and car shakes a lot, but it was shaking before i put CAI on and even before i cleaned throttle body, i see it getting worst when i put AC on but when i put car on park it doesn't shake at all...it doesn't shake when i'm driving neither, only when in idle....anybody know what this problem is? I think i'm going to have to make new thread about these disconnected hoses....
Old Jun 17, 2002 | 12:55 PM
njmaxseltd's Avatar
Thats the breather for the tranny. They don't go anywhere, they just hang out.
Air intake temp sensor perhaps? There should be a place to put that in the intake.
PULL THE CODES!
A shake could be caused by a misfire, low compression in a cylinder or faulty, cloged injectors bad spark plugs. You may be in need of a fuel system service. 3M has a kit that will clean your entire fuel system. Most dealers will perform this service for you. Cost is around 100 bucks.
Hopefully you don't have cylinders with low compression, that would mean engine trouble. Pistons/Rings/Valves. A compression test would pick up any internal engine problems.
tsi6001
Oct 3, 2022 10:23 PM
MatthewsMaxima
Sep 11, 2015 03:21 AM
carlosvq30
Aug 17, 2015 11:32 AM
crsmax
Apr 17, 2001 12:58 AM
