Just wondering what everyone has their agx's set to
Old Jun 16, 2002 | 08:31 PM
NotNew!!NewSN!!'s Avatar
after much tests ive come to realize the best setup of agx's on progress springs are 3 on the front and 3 on the rear for me. im guessing due to such a heavier load on the front with the engine and what not, the stronger damping lets it be a lot more controlled but due to the softer springs it still has a lot of suspension travel. since i dont have a system or anything in the rear, i need to use the springs to my advantage becuz when i make the shocks stiffer it just gets bouncy over every bump becuz nothing is rilly pushing down on them to make it rilly have a long suspension travel. ive had this setup for a day and it feels much much smoother then stock ever was and still takes turns like a champ with no body roll whatsoever, im just curious to see what everyone has their agx's set on whic springs, and what the ride is like, maybe this will help others decide.so.......
progress springs, 3 front, 3 rear.
Old Jun 16, 2002 | 08:43 PM
itsgt's Avatar
Re: Just wondering what everyone has their agx's set to
i had 2front,4back as default...wanted something more stiffer, went with 2front, 6back......Then wanted even more stiffer and best performing handling so i went with 3front, 7back and i love the feel of the rode and handling , so im sticking with them.
Old Jun 16, 2002 | 09:48 PM
ericdwong's Avatar
4 front, 8 rear.
Old Jun 16, 2002 | 09:55 PM
black019's Avatar
4 & 4
Old Jun 16, 2002 | 10:21 PM
krzymax's Avatar
Maxima owner since 2000
<--2 / 4-->
Old Jun 16, 2002 | 10:27 PM
CASS98SE's Avatar
2/4
I had it on 4/8 very nice around town, but it gets annoying on MN highways
2 front 4 rear is nich on the highway with progress springs.
Old Jun 17, 2002 | 12:58 AM
Iilac's Avatar
Spelled with a I not a L for Iilac. Prounced Ii-eee-ack.
3 in the front and 6 in the back.
Old Jun 17, 2002 | 08:53 AM
krzymax's Avatar
i haven't played around with the settings and am wondering what would be a good setting for ground controls with default spring rate?
Old Jun 17, 2002 | 10:54 AM
njmaxseltd's Avatar
B&G + AGX = 1 & 2 Smooth, yet nice and firm sporty ride.
Old Jun 17, 2002 | 11:55 AM
iwannabmw's Avatar
With H&R's
Either 1/1, 2/8 or 4/8.
4/8 only for competition or track events.
Old Jun 17, 2002 | 11:56 AM
Albertt's Avatar
Like Njmaxseltd, I like it cushy >>
I have H&R springs, but I have the damping set at 1 and 2 for the softest ride. When they were first installed, I left them at the original setting of 2 and 4, but I felt that the ride was too uncomfortable.
Jeez, those of you who have them set to 4 and 8, I'm surprised that you haven't shook your fillings out of your teeth.
Old Jun 17, 2002 | 01:34 PM
Kevin's Avatar
Is there minimal body roll even on the softest settings?
I remember the ride I took in njmaxseltd's car and hte body roll was like nothing, but I don't remember what settings they were on.
Old Jun 17, 2002 | 01:43 PM
Lime's Avatar
with H&R...2/4 and it's too loose for me...gunna adjust I think. Possibly 3/6.
Old Jun 17, 2002 | 01:46 PM
i find that the ride only becomes uncomfortable when the rears are tightened up due to there not being much load back there.
Old Jun 17, 2002 | 02:15 PM
MardiGrasMax's Avatar
1f/5r I like how it bieng stiffer in the back makes the car rotate better in turns.
Old Jun 18, 2002 | 05:18 AM
Albertt's Avatar
Kevin, body roll characteristics do change >>
It seems as though the body rolls more on sharp transitions with the lighter settings. But for me, the extra handling isn't worth the discomfort.
My advice, start off with the 50% settings of 2 and 4, then alter the settings from there as you like.
Old Jun 18, 2002 | 05:42 AM
Kevin's Avatar
Re: Kevin, body roll characteristics do change >>
Thanks Albertt,
Do you have H&R springs? was it that uncomfortable even with H&R's? I think My Eibach/Tok setup is a lot less comfy then I would like.
Kevin
Old Jun 18, 2002 | 06:39 AM
Albertt's Avatar
Kevin: I went from stock GXE springs to H&Rs >>
Thanks Albertt,
Kevin
And even though the H&Rs are noticibly stiffer, turning the damping down on the AGXs makes it bearable. Eibachs are supposed to be stiffer than H&Rs, that could explain your feelings about your setup compared to those with H&Rs.
Old Jun 18, 2002 | 08:04 AM
i def agree, to get a great rotation of ur car stiffen up the rear more then the front to create a somewhat sway bar, i just made this thread so everyone understands how to adjust their agx's. for comfort i feel a stiffer front of 1-3 and keeping the rears not above 3 will provide that, for handling, probably keeping the fronts at 3 and the rears at 8 will help prevent the understeer, u dont want the front too stiff or ull get the understeer again.
GregL65
Jan 17, 2020 08:01 PM
Max139617
Sep 20, 2015 07:25 PM
Max139617
Sep 20, 2015 07:09 PM
