Manual Radiator Fan Control for Drag Racing
Old May 4, 2012 | 06:05 AM
  #81
Aaron92SE's Avatar
NWP Engineering.com
Originally Posted by ABIGBRAIN
Can these pics be reposted please?
Here's one I made for the 3rd gen Maxima:
It's basically the same exact diagram as the one Jime posted, but it's for the 3rd gen instead of the 4th gen. The terminals will be different if you have a 95 Maxima.
What I am running right now is simply a SPST switch that grounds the wire for the high speed fans. I don't see a reason to ever run the low speed fans. If you need your fans to kick on, you probably need them to kick on full speed.
I used a red inline wire splice that simply taps into the wire without cutting it into two pieces. When you ground the wire, the ECU will kick the fans on.
Old May 4, 2012 | 07:31 AM
  #82
Jime's Avatar
BkGreen97
Apr 2, 2016 05:47 AM
captchaos
Mar 15, 2016 12:18 PM
Smackasmith
Feb 1, 2016 12:40 AM
Starrider
Dec 18, 2015 04:43 AM
videomano
Sep 8, 2015 03:28 PM
