uh-oh my car wont start
Old Jun 17, 2002 | 03:58 PM
Redmax's Avatar
Redlinemax Owner
it keeps sounding like it has enough battery power but not getting any gas. can anyone help?
Old Jun 17, 2002 | 05:30 PM
Toolrocks's Avatar
Mine is doing a similar thing but it eventually starts after about 10 secs. Find the fuel hose from the top of the fuel filter, have someone turn your key to the on posistion while you lightly pinch that hose. As the key is turned to on you should feel pulsating in the hose - that'll mean that your fuel pump is delivering fuel. If you don't feel that pulsating then further diagnose your fuel pump. If you do feel the pulsating then you are where I am at in my diagnostics of my own car. I am suspecting either a faulty fuel pressure regulator or a leaking or weak injector. Too early to tell. I need some free time to diagnose better. I'll post if I find anything out. Good luck w/ yours.
Old Jun 17, 2002 | 05:33 PM
Chunger's Avatar
My other car is a Hybrid
You'll smell unburned gas out the tailpipe if you're getting fuel but no spark after a few attempts.
Old Jun 17, 2002 | 05:40 PM
97GLE's Avatar
Did you check all your fuses? My fuel pump fuse blew before. Check the ones under the hood, too.
Old Jun 17, 2002 | 06:52 PM
BBaker025's Avatar
You might not have any amps flowing through your battery!
Old Jun 17, 2002 | 07:21 PM
Redmax's Avatar
Redlinemax Owner
my mechanic just told me its an ecu. does anybody know how much they cost?
Old Jun 18, 2002 | 01:12 AM
Chunger's Avatar
I doubt it is a burned ECU... why does he think that? If your really unlucky enough, though... check with junkyards for a used one.
Old Jun 18, 2002 | 05:25 AM
caneyebus's Avatar
hmmm
are you using the key??? hehe just kidding get your sensors checked..
Old Jun 18, 2002 | 06:05 AM
njmaxseltd's Avatar
Had the same issue with an I30 - turned out to be the crank shaft position sensor. The car can't start if it doesn't know where Top Dead Center is.
There are two sensors, one is on the crank under the lower pullie and the other is on the oil pan near the bell housing.
If either of these sensors fail, you get a no start condition.
Old Jun 18, 2002 | 07:19 AM
Toolrocks's Avatar
Will either sensor trip the CEL? I've been reading about the POS and REF crank sensors but don't recall if they can trip the CEL. Thanks.
Old Jun 18, 2002 | 07:53 AM
Redmax's Avatar
Redlinemax Owner
There is suppoesed to be a lit green light on the ecu and there are no lights coming on.
Old Jun 19, 2002 | 08:37 AM
Redmax's Avatar
Redlinemax Owner
well the nissan guy i knew came back yesterday and checked out my car. come to find out, the 99 se-l keys have a computer chip in them so that the car will start. he said the mobil speed pass that my wife has on her keys erases the codes on the key. when you go to start the car with this key without any programming on it, the car thinks its being jacked and then shuts everything down. The ecu will recieve signals, but it is told not to send any signals out. theres this computer that nissan has called the consult which reprograms your car and keys together. they will do that to my car today to get it started. he also said that this can happen if you stick another nissan key in the ignition by mistake. which i know that day i stuck my 90 maxima key in the ignition and tried to turn it when i realized oops wrong key! well i gues you live and learn.
Old Jun 19, 2002 | 09:53 AM
Toolrocks's Avatar
Wish my problem were that easy. Congrats - speed pass huh, that's interesting.
Old Jun 20, 2002 | 09:39 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Well at least we know it wasnt a wiring problem...(private joke) LOL
So it was the speedpass huh? Damn and those two tows....OMG!!! O yea uhhh since ya found that out....airports,cousthouses,etc..those metal detectors.....Ummmmm they occasionally do the same thing.
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Balkins
Aug 12, 2015 06:39 AM
Maxboy23
Aug 11, 2015 11:59 AM
