Question on suspension
Old Jun 17, 2002 | 06:27 PM
maxima168's Avatar
how much does bushings go for? where can i get them cheap?does it help that much? is there such thing as a front sway bar for the maxima? is it worth getting the rstb?
Old Jun 17, 2002 | 10:32 PM
speedemn's Avatar
Hey there,
I'm new here but I've been doing a lot of research on suspension since I'm doing mine real soon. Our Maximas apparently have a front swaybar but I hear that it is best to keep that stock. If anything, upgrade the bushings.
For the RSTB, I hear that you probably will not notice the difference with it on or off.
Hope this helps.
Old Jun 17, 2002 | 10:51 PM
95emeraldgxe's Avatar
Re: Question on suspension
front sway bar no..........front strut bar yes........... rstb is kinda worthless for the maxima - doesnt show much improvement in handling
Old Jun 18, 2002 | 06:52 AM
maxima168's Avatar
thanks. since you doing ur suspension 2. where have u found bushings? is there different kinds? how much do they run for? because all i need now is a rsb and the bushings.
Old Jun 18, 2002 | 07:15 AM
speedemn's Avatar
No actually I didn't look into the bushings. I was just planning on doing struts/shocks, springs, FSTB, RSB.
Old Jun 18, 2002 | 07:19 AM
maxima4me's Avatar
If you guys are doing suspension work you should check out the STICKY
That should answer most of your questions
Old Jun 18, 2002 | 07:33 AM
njmaxseltd's Avatar
Which bushings? If your asking about the front sway bar bushings, yes there is an upgrade for them. Courtesy Nissan, found on the web sells Energy Suspension Urathane bushings for the front sway bar on our cars. YES OUR CARS HAVE FRONT SWAY BARS. Every car on the road has some sort of sway or stabalizer bar on the front suspension.
http://www.courtesyparts.com/energys...on/maxima.html
Part number 4803G - You need 4 bushings.
The other bushings on that page, part number 7-5118G are the bushings that secure the bar in place - There are two of them and I think the price shown is for the set of two.
No, but a Rear Stabalizer Bar (RSB) will give you the stability your looking for. Addco makes a nice bar for the Maxima for about 100 bucks.
Old Jun 18, 2002 | 10:21 AM
maxima168's Avatar
if we have a front sway bar than that means there is no need to change it right?
Old Jun 18, 2002 | 11:09 AM
njmaxseltd's Avatar
That is correct. Just upgrade the bushings if you'd like to stiffen up body roll a bit more. I did that when I put the AGX's in. Very easy to change them, the old ones were all squashed anyhow. The larger bushings that hold the bar in place are pretty solid, I left my stock ones on, but the end link bushings take a beating. Just changing them yield good results.
Old Jun 18, 2002 | 12:47 PM
maxima168's Avatar
did u replace it with stock bushings or aftermark? how much did u pay for the bushings?is there a need in getting a adjutable rsb? what about the adjustable upper arms and limited slp differential? what are they? do they need to be added or changed?
Old Jun 18, 2002 | 01:21 PM
njmaxseltd's Avatar
WOW slow down, to many questions, some of which I already answered in my above posts.
Try using the search feature on this board. There is a ton of information on the issues your inquiring about.
Old Jun 18, 2002 | 05:11 PM
maxima168's Avatar
i did some searching didnt really find anything helpful like where to get them and how much the bushings go for. i heard i need 2 mechanics to weld the old ones off and put on the new bushings.
i couldnt find anything to do with adjustable upper arms and limited slp differential. my whole suspension is almost complete. i just need to know if there is more stuff i need to order.
Old Jun 18, 2002 | 05:27 PM
speedemn's Avatar
I too am new here and am just doing my suspension now. The search brought up this link. I found it really helpful to identify all the necessary bushings, boots, stops, etc.
http://forums.maxima.org/showthread.php?threadid=72678
Good luck.
pears
Sep 18, 2015 05:25 AM
Violator
Sep 9, 2015 10:14 AM
Johnny9595
Sep 3, 2015 05:18 AM
A32goldylocks
Sep 2, 2015 06:39 AM
