EVAP control system pressure sensor location?
Old Jun 19, 2002 | 05:29 AM
elcid's Avatar
Anybody know where this sensor is? I've already searched, but can't get enough detail as to where exactly it is. Also while searching I've read about cleaning the evap valve, where exactly is that? Thanks! Error code is 0705 never goes away, but then again haven't done anything to get rid of it. Any help would be great.
Old Jun 19, 2002 | 06:04 AM
Albertt's Avatar
Elcid: I'm not sure where the sensor is >>
And I'm not sure there is one.
But I do know that the evap canister, valve and solenoid are located behind the rear driver's side wheel.
There is a control valve under the hood on my '97 as well.
Old Jun 19, 2002 | 06:10 AM
elcid's Avatar
Re: Elcid: I'm not sure where the sensor is >>
Thanks. Code 0704 reffers to the evap sensor. Do you know exactly where the valve is, just so I don't take apart the wrong thing. Thanks
Old Jun 19, 2002 | 06:23 AM
Albertt's Avatar
Elcid: During my lunch hour, I'm going to see if I can >>
...take a look at my FSM. Bear in mind that it for a 1997 (Fed-spec) car.
THe valve is located next to, or rather connected to, the evap canister. The canister looks like a black plastic box, about 4"L X 6"W X 9"D with a grid pattern molded on the outside. In addition to the solenoid and valve, there will be small hoses coming from it.
Old Jun 19, 2002 | 07:40 AM
elcid's Avatar
Re: Elcid: During my lunch hour, I'm going to see if I can >>
Ok yes I do have that box, is it a like a cicular white thing?
vybz05
Dec 10, 2015 07:38 PM
doobadoo
Aug 15, 2015 06:43 PM
acw
Aug 7, 2015 04:20 PM
