CV boot replacement
Old Jun 19, 2002 | 06:54 PM
ladeesman's Avatar
CV boot replacement
Okay so today the dealership tells me that both front cv boots are cracked. He said i have about a month or so to take care of it and that to repair them it was going to be about 175 a piece plus 220 labor. I've heard that it can be done cheaper, anyone have suggestions? I need help bad and I don't have that money......
Old Jun 19, 2002 | 07:07 PM
mzmtg's Avatar
Minister of Silly Walks
You can get brand new (not remanufactured) axles for about $125 per side. You can install them yourself too. It's not that hard.
www.raxles.com
They rock!
Old Jun 19, 2002 | 07:15 PM
ladeesman's Avatar
Are you sure I can?
Old Jun 19, 2002 | 07:30 PM
JustTry's Avatar
me and my uncle did it......got them both for $300 with lifetime warranty....and we installed them ourselves...its fairly easy...
Old Jun 19, 2002 | 07:38 PM
ladeesman's Avatar
Well I'm fairly mechanically inclined but I don't know much about the axel/wheel area. Mostly electrical and engines. So can I do this at my house and what do I risk messing up. Where can I get directions?
Old Jun 19, 2002 | 09:15 PM
max1ma97se's Avatar
take out the drive shafts and replace the cv boots yourself. pep boys sells the cv boot rubber thing for 15 each i replaced 3 of my 4 its a pain but worth saving hundreds on labor
Old Jun 19, 2002 | 11:03 PM
asianmusketeer's Avatar
i got my right side changed for $20.
Old Jun 20, 2002 | 05:51 AM
BJJ's Avatar
BJJ
Re: CV boot replacement
You can replace them yourself, it's not as bad as it looks. I just replaced both my drive axles 2 days ago and it only took about 2 hours. If you are coming to the meet today I will tell you about them there.
Old Jun 20, 2002 | 06:02 AM
njmaxseltd's Avatar
Try taking it to a local shop instead of the dealer. I bet you cut that price in 1/2. The replacement boot is only a few bucks. The rest is labor. The dealer gets like 80/hr for labor and they go by the book. A local shop might do the job pretty quick and only charge you for the time it actually took to replace the boots.
Old Jun 20, 2002 | 06:15 AM
jayanth's Avatar
Boot replacement outer both sides -$65 to $85.
Boots outer $11.00 each at carquest.
Make sure your joints are OK before replacing the boots.I recommend buying some CV joint grease ($4.95 valvoline )and put it into the boot using a grease gun.It will give you added protection.Do this once in 3 days so that you can keep the dirt out.
My 0.02
Take care ,
Jay
Old Jun 20, 2002 | 07:47 AM
sinewave's Avatar
Are you sure I can?
Abbreviated instructions are at the bottom of the first page of this thread. If you have the right tools, it's an easy job.
http://forums.maxima.org/showthread....highlight=axle
PH98I30
29
Feb 10, 2025 12:03 PM
mvm062
Nov 30, 2020 09:00 AM
dvcamp
Sep 18, 2015 10:17 AM
Maxima30
Sep 7, 2015 06:13 PM
TheMafia
Sep 4, 2015 08:26 AM
