popping sound when clutch engages
Old Jun 25, 2002 | 07:54 AM
NotNew!!NewSN!!'s Avatar
last couple weeks ive had some weird noises. when im taking off, maybe a milisecond after the clutch engages i get a popping sort of noise coming from the drivers wheel, or right in front of me im not sure, i just know its directly in front of me. i didnt relate it to the clutch until i was in my driveway and would let it engage with no gas at all and at the catch point everytime, it would give me the popping noise when it engages and a couple seconds after while the wheels were rolling. its not a pritty noise and its def worrying me, anyone? thanks
Old Jun 25, 2002 | 08:10 AM
QikEnuf's Avatar
does it just pop once or does it do it several times, if it does it several times then you probably have the infamous clutch chatter
Old Jun 25, 2002 | 08:12 AM
njmaxseltd's Avatar
Transmission?
CV Joints?
Pressure Plate?
Throwout Bearing? - Naa that would only make noise while your disengauged.
Pilot Bearing?
Slave Cylinder?
Just a few items to think about.
Old Jun 25, 2002 | 08:14 AM
ejj's Avatar
ejj
I had the same type of sound that you're describing a few months ago, and for the life of me I couldn't figure it out.
Turns out that I had 1 REALLY lose lug nut on the drivers front wheel.
Old Jun 25, 2002 | 11:49 AM
pop a couple times, but its not like the car shakes or chatters or anything, u just hear them, and somewhat feel them under ur foot, but no actual chatter, more just hear them. i think when i let my friend take it out he destroyed it and clutch is on its last life, its not slippin at all though, just catchin rilly soft and makin those noises
Old Jun 25, 2002 | 12:51 PM
QikEnuf's Avatar
hmm...you could do the 5th gear test to see if it slips, how old is the clutch???
Old Jun 25, 2002 | 01:32 PM
70k miles on it, picked up car at 46k and felt little bit more wear then usual on it cuz it was a city only driven car(more wear and tear). its been through autocross and recently i think my friend scorched it, thats when noises begin. what is 5th gear test, dont tell me i take off in 5th gear
Old Jun 25, 2002 | 01:41 PM
blizz20oma's Avatar
I'm so hood
The fifth gear test is putting the car in 5th gear while at about 40-45mph to keep the engine revs low. Then, when you're in gear, floor the gas. If the engine revs but doesn't pick up speed, the clutch is slipping enough to where you should replace it. However, you already said it's not slipping so I dunno if this applies, but give it a try anyway and see what happens.
Old Jun 25, 2002 | 05:17 PM
QikEnuf's Avatar
sorry..forgot to explain the 5th gear test...anyway from what you have said above, sounds like the clutch is toasted, even if it does pass the 5th gear test, I would start looking into it.
Old Jun 25, 2002 | 07:46 PM
CSever05's Avatar
CV Joint?
I was thinking CV joint too, but it's probably a worn clutch plate.
Old Jun 25, 2002 | 08:03 PM
passes 5th gear test fine, and it def doesnt slip, just doesnt have bite, i duno, i want to do act clutch, but not if it isnt done, but if the poppin is cuz of clutch i will, i just dont want to change the clutch to find out its somewhere else.
user 11122324
42
Jul 18, 2022 03:35 PM
AaronL
Aug 8, 2020 10:31 AM
D Mason
Jun 21, 2016 04:43 AM
Need help
23
Oct 2, 2015 08:56 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
