headlight problems...please help
Old Jun 25, 2002 | 02:01 PM
cushdan's Avatar
Hey, I have a 96 SE and just the other night i was driving and my right foglight and left headlight both went out. Now my high beam light stays on and even with my high beams on i can turn my foglights on and off (which i normally couldnt do). I had an extra headlight bulb so i went to replace it but when i took it out the plug of the wiring that goes into the bulb was burnt and there was melted plastic. do you think i have major wiring problems or is it something easier. Thanx for any help.
Cushdan
Old Jun 25, 2002 | 02:13 PM
mzmtg's Avatar
Minister of Silly Walks
Are you using OEm bulbs or aftermarket?
You've described the symptoms of using a bulb with too high of a wattage.
Old Jun 25, 2002 | 02:16 PM
ZeRo MaX's Avatar
If using a bulb of high wattage does that.. when i clip off the lil nub on the bulbs of the corner headlights... will it burn like that? cuz it makes the light brighter.. cuzing more wattage.. correct?
Old Jun 25, 2002 | 02:23 PM
mzmtg's Avatar
No, you are still only pushing 27 watts. It is the 100 watt and over headlight bulbs that cause problems.
Old Jun 26, 2002 | 08:01 AM
cushdan's Avatar
bulb type
they are aftermarket xenon bulbs.
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Apr 8, 2016 06:45 PM
knight_yyz
Nov 1, 2015 01:34 PM
trsandrew
Oct 25, 2015 02:47 PM
Noela
Sep 26, 2015 08:22 AM
