clear corner question
Old Jul 1, 2002 | 08:54 PM
johnvt1111's Avatar
i don't have the one bolt for the left corner clear, i don't actually know if it's called a bolt, but its put into the clear corner and then it kinda just pops into the front and is secured, does anyone know where i can get one? i really need one bad, i looked at the dealer and they said they only had factory ones.......so i have it taped on...please help
Old Jul 1, 2002 | 09:58 PM
chigga's Avatar
damn that sux. wherever u got ur clears from, try calling them and see if they can help.....dunno what else to try...
Old Jul 2, 2002 | 08:26 AM
johnvt1111's Avatar
i bought them from a guy on the org who says he sent them the way he got them, which is bull****
Old Jul 2, 2002 | 08:51 AM
Jamsan's Avatar
the outer piece on the clears just pop in...you can screw them in from inside the fender, but they dont come with them....
Old Jul 2, 2002 | 10:15 AM
johnvt1111's Avatar
so i can just take a normal screw and screw it in from under the car?
Old Jul 2, 2002 | 10:25 AM
Tifosi's Avatar
John,
You have asked this question already and I gave you a reply..
previous thread...
http://forums.maxima.org/showthread....hreadid=132242
Is there something you are still unclear about?
Old Jul 2, 2002 | 10:34 AM
johnvt1111's Avatar
Originally posted by Tifosi
John,
previous thread...
yeah there is, i'm wondering the easiest way i can do this? I don't know much about cars, all i know is that i have only one snap in bolt, and i need 2, so if i am being retorical and repedative sorry, just want a clear cut answer
Old Jul 2, 2002 | 10:46 AM
Tifosi's Avatar
Oh no, no problem at all. I totally understand that. Yeah that is the easiest way to put the clears on... screw it from inside, from under the car. More importantly, get a bolt that matches the thread pattern from any hardware store first. Good luck. You'll definitely enjoy the looks of the clear corners.
Old Jul 2, 2002 | 11:43 AM
johnvt1111's Avatar
there is an peice underneith the car, so i guess i have to take that off to be able to get behind it so i can screw it in correct?
Old Jul 2, 2002 | 11:48 AM
Tifosi's Avatar
Yeah, there should be a plastic flap (lining) directly underneath the car just in front of the front wheels, there should be a couple of screws or snap screws that hold them in place, unscrew or unsnap those and you can pull the lining away and stick your arm in from there. Make sure you get some washers too.. so the sequence from the inside is.... Bolt-washer-bumper(hole)-washer-clear corner.
doctorpullit
Apr 23, 2017 05:35 AM
NERDJUSTBNME
Sep 30, 2015 03:20 PM
Blkkn8
Sep 22, 2015 06:37 PM
jchronis2552
Sep 21, 2015 05:52 AM
Steven Orozco
Sep 12, 2015 10:41 PM
