checking iac valve
checking iac valve (again) did ohms test
i just did the test i got about 30 ohms from 1,2-2,3-3,4-5,6 (all about 30 ohms) but i got 60 ohms on 3,4 ??? this means its a bad iac valve
ps: i had a high idle sometimes
change fuel filter
clean TB
new filter
change fuel filter
clean TB
new filter
Clean the IAC valve.
Your test results were fine.
It sort of comes apart and then you can use throttle body cleaner in it to clean things up. That should make it stop hanging up, which is probably causing your high idle.
Also check and make sure your throttle cable isn't binding on anything and has just a slight bit of play.
