oil leak that wont quit>>>
Old Jul 7, 2002 | 08:14 AM
DAREN's Avatar
it seem to be coming from the rear main seal or rear of the upper oil pan. i have already replaced the rear main seal (twice) and re-siliconed the upper oil pan to engine block 2 times. i have also replaced the 2 crecsent shaped gaskets for the upper oil pan to engine block.
please help
Old Jul 7, 2002 | 08:18 AM
Lime's Avatar
my car had a rear main seal leak; it should be covered under warrantee if you still have one. If not, ugh, you have to remove the oil pan and drop the tranny to replace.
if you can get in there and clean most of the oil up, then check in a day, to see where the oil is actually from, then you can be more sure. If it's just the oil pan, that's not so bad.
Old Jul 7, 2002 | 10:38 AM
njmaxseltd's Avatar
Hi Erica!
Old Jul 7, 2002 | 10:55 AM
Toolrocks's Avatar
I had my rear seal replaced when I had my ACT clutch installed at the dealer. I took it back 3 times before they finally got it to quit leaking. Good luck. I can't offer any advice - I had someone else do mine. Now my tranny leaks. There's always something.
Old Jul 7, 2002 | 02:56 PM
DAREN's Avatar
is this a common accurance with 4th gens. that the rear main seal wont seat correctly unless the oil pan is removed. while the tranny is out.
Old Jul 7, 2002 | 03:13 PM
Toolrocks's Avatar
Not sure about that but my FSM clearly states that all that needs to be removed to properly replace the rear seal. The first time the dealer attempted to replace mine; they tried to do it w/o removing the oil pan - didn't work. 2nd time they removed the pan and it still didn't work. The third time was just right, Goldilocks hehe A different tech also performed the work.
I figure the shaft in the engine develops a little bit of a wobble over time that is hard to seal with a nice, new, even circle - since the original seal got to break in while the wobble was developing
Old Jul 7, 2002 | 03:49 PM
DAREN's Avatar
what really sucks is that i have a new motor waiting for instalation becasue of this problem. now i find out that all i have to do is remove tranny and oil pan to do it right.
Old Jul 7, 2002 | 04:43 PM
Toolrocks's Avatar
May I ask how much and is it a complete motor? I think I might have a blown head gasket and I'm starting to investigate my options. Thanks.
Old Jul 7, 2002 | 05:12 PM
DAREN's Avatar
$600 for motor. i bought it complete with a tranny for $1000. the tranny is on my car alredy, the old blew its seals then bearings. if i get this oil leak fixed i will sell it if not then it goes into my car whole or maybe just the oil pan. to be honest if my car stops leaking i might do the "impossible" and try to swap it into my 3rd gen. the motor came with the ecu harness so all i need is the ecu itself.
any way thanks a lot for the info. that detail about removing the tranny and oil pan to properly install the rear main seal is not included in the chilton or haynes manuals.
Old Jul 7, 2002 | 06:47 PM
JsL's Avatar
JsL
Mine just started leaking too!! I think it is also coming from the back of the oil pan because I dont see any oil leaking from the oil filter or drain plug. I hope when i take my car in for the alternator recall, they will take car of it also under warranty.
Old Jul 7, 2002 | 07:48 PM
Lime's Avatar
Tooooommm, I was taking over for you this weekend on being helpful.
Anyway, this seems like another Knock Sensor type problem; something that needs to be replaced that isn't a recall. GRR.
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
