Pic of wheels with 30mm offset?
Old Jul 8, 2002 | 03:16 PM
1FSTMAX's Avatar
Does any one have pictures of thier 4th Gen Maxima with 30mm offset wheels?
Old Jul 8, 2002 | 03:17 PM
Jeff92se's Avatar
I'm needing a caw
What size rim? Thinking about a set of rims?
Old Jul 8, 2002 | 03:20 PM
1FSTMAX's Avatar
The rim size is 17x7.5
Also will 235/45/17 tires fit these wheels?
Old Jul 8, 2002 | 03:27 PM
Jeff92se's Avatar
I'm needing a caw
I "think" 7.5 will be fine w/ the 30mm offset. 8" might be pushing it. 235 is okay for 7.5 but a no no for 7" rims.
Old Jul 8, 2002 | 03:34 PM
1FSTMAX's Avatar
What about 18x8 with 30mm offset? Will it smack against something?
I'm sorry for asking all of these questions.
Old Jul 8, 2002 | 03:37 PM
Jeff92se's Avatar
I'm needing a caw
18x8, 30mm offset and 235-40-18s should work. But I think they will be very close to the outside fenderwell. Depends on how low you are. Some fender rolling might be in order.
You are looking at rims? Which ones?
Old Jul 8, 2002 | 03:44 PM
1FSTMAX's Avatar
I posted a thread earlier, about 350z wheels. I went to see them and found out that they have a 30mm offset. I¡¦m still deciding between 18x8 and 17x7.5
http://www.nissandriven.com/m/cma/i/...d_big6.jpg.jpg
18x8
Or
http://www.nissandriven.com/m/cma/i/...03_revised.jpg
17x7.5
Old Jul 8, 2002 | 03:45 PM
MENYCE's Avatar
I have 18"x 7.5" with 245/40/18 and it is chillin. Tires are a little bit bigger but it rides love and lookes mean with my Maxspeed AGX setup.
Old Jul 8, 2002 | 06:06 PM
I30tMikeD's Avatar
I think a 30mm offset will have your tires sticking out a little passed the fenders in the front. Not a lot. I personally like the flush look.
I have 40mm and the front is perfectly flush. The back could have used 35mm offset, they are inset just a tad.
Old Jul 8, 2002 | 06:20 PM
97GLES's Avatar
i think the best fit for the max is 38mm in front & 35mm in rear.
Old Jul 8, 2002 | 10:18 PM
1FSTMAX's Avatar
I'm thinking that these wheels will look like steam rollers on a 4th gen.
Old Jul 8, 2002 | 11:00 PM
Kevin Wong's Avatar
I have 17X8 32mm offset wheels. They just barely clear the Brembo brake kit, because of the spoke design. I'll try and get a pic sent to you tomorrow.
Old Jul 8, 2002 | 11:09 PM
1FSTMAX's Avatar
Cool!
Old Jul 9, 2002 | 12:00 AM
i30dude's Avatar
It should clear the frenders just fine but offset is when it cleard the breaks i have 35offset and they are perfict 30 should work but its gone be very close to the breaks
Old Jul 9, 2002 | 12:54 AM
chris j vurnis's Avatar
With a 30mm offset and 7.5" width wheels, they will stick out about 1/2" beyond the quarter panel assumung around -.3 camber angle.
RinconI30
Nov 10, 2015 10:55 PM
I<3 A32's
Sep 10, 2015 11:07 AM
dcam0326
Sep 8, 2015 11:02 PM
jfl330
Sep 4, 2015 01:44 PM
