dash lights question
Old Jul 9, 2002 | 11:25 AM
Fish254's Avatar
on my rmp cluster it lights up normal till about 5 thousand rmp and the rest is is very dark also where is shows the temp thats does no light up at all what can this be a the bulbs are burent?
Old Jul 9, 2002 | 11:50 AM
98fiveSpeed's Avatar
yes, most probably ur bulb is burnt out, replace it. the temp and the 5000+ side of the tachometer is illuminated by one bulb.
Old Jul 9, 2002 | 10:14 PM
iregula's Avatar
i wish i could do this mod
Old Jul 9, 2002 | 10:52 PM
808_Pimpn_max's Avatar
how much bulbs do you need???
Old Jul 9, 2002 | 11:46 PM
Speebs's Avatar
I aim to misbehave.
There are five bulbs that illuminate the guage cluster. They are 12V, type 194 bulbs. One bulb lights up the fuel guage, one lights up the left side of the speedometer, one does both the right side of the speedometer and the left side of the tachometer, and the fifth bulb illuminates the right side of the tachometer and the whole temp. guage.
Swapping out the bulbs is very easy once you've taken off the appropriate dash trim pieces. I don't have any direct links for you, but if you search around you can find one pretty quickly. Takes about 15 minutes. Easy mod!
Old Jul 10, 2002 | 10:10 AM
Fish254's Avatar
can i put led blue bulbs in there??
Old Jul 10, 2002 | 11:29 AM
thank so its 5 194'z ...ok got it
Old Jul 10, 2002 | 01:45 PM
D1NOnly34's Avatar
yeah you can put led blue bulbs...as long as they are 194 leds...also, be careful which ones you get, if you put the 4-leds, then it will have hot spots, by that I mean you will see spots on your dash where it will be brighter than the rest of the dash and it wont' look as good, get the 1-LED's, a little dimmer but bright enough to look good
Roymg
Sep 3, 2018 05:10 AM
AnsonJ
Jun 2, 2017 01:35 PM
King_Ten_Ahead
Sep 30, 2015 04:27 PM
Jeffesernia11
Aug 23, 2015 06:09 PM
doobadoo
Aug 15, 2015 06:43 PM
