what size wrench for oil change
Old Jul 9, 2002 | 12:59 PM
eljo's Avatar
I am going to change the oil of 98 maxima by myself for the first time. I would like to know what size wrench should I use for the oil change. Thanks
Old Jul 9, 2002 | 01:15 PM
skeelo34's Avatar
Re: what size wrench for oil change
I believe its size 14mm (90% sure), if not its 12mm. Its one of those two definitely.
Old Jul 9, 2002 | 01:29 PM
guido_sst's Avatar
The oil drainplug is 14mm, you'll also need a 10mm and a phillips head screw driver to remove the plastic shield. Some sort of wrench to remove the filter is handy, but you can drive a screwdriver through it to use as a handle in a pinch (beware, this is messy).
Old Jul 9, 2002 | 01:49 PM
skeelo34's Avatar
What plastic shield?
Old Jul 9, 2002 | 02:01 PM
guido_sst's Avatar
The plastic undertray that covers the oil fliter, crank pulley, etc.
Old Jul 9, 2002 | 03:04 PM
FLO_BOY's Avatar
you don't HAVE to remove the plastic shield...I didn't...
But, it does make the job easier...
FLO_BOY
Old Jul 9, 2002 | 03:14 PM
BrianV's Avatar
Yes it's 14MM, and I've found that you don't need to remove the plastic if you have a small enough wrist to fit it around it to unscrew the filter (it bends the plastic a little, but it pops back into place once you're done).
When I do an oil change, I take my ratchet, 14mm deep socket, new oil filter, oil pan, jack, and new oil.
Old Jul 9, 2002 | 05:10 PM
MDubya
my 2 cents
seriously.. not being a d$ck but. oil plug size.
Are you planning to lay out the tools the day before you do this.
Old Jul 9, 2002 | 06:31 PM
SlowJoeMax's Avatar
Re: my 2 cents
Old Jul 9, 2002 | 06:54 PM
pocketrocket's Avatar
Re: my 2 cents
M12-1.25
97_GXE
20
Sep 17, 2015 08:12 PM
minsbang
Sep 11, 2015 08:48 PM
ag90fox
Sep 9, 2015 12:22 PM
Hdnseek
Sep 9, 2015 05:55 AM
sdotcarter
Sep 2, 2015 09:53 PM
