Fs: Pistons Pistons Pistons
Old Jan 31, 2007 | 06:51 PM
BlackMaxGTR's Avatar
"DRAG" A game of thousandths
***** UPDATE!! ok i know that a lot of u ppl reading this thread would like to have these and i need to get rid of them, so if someone can take them off my hands before the 13th, thats a week from today, i will take 750 shipped!!! for these beautiful pistons and everything included!! *****
hey guys i got some low compression pistons for the mighty vq!! info i got is as follows:
Type: ARIAS
Cylinders: 6
Make: nissan
Model: vq35
spec: 20# tc gas
head: 4 valve
head cc: 57
displacement: 215.80 >>>>>>>> 3537.70
finished bore: 3.780 >>>>>>>>> 96.01
stroke: 3.205 >>>>>>>>>>>>> 81.41
rod length: 5.669 >>>>>>>>> 144.0
comp. height: 1.174 >>>>>>>>> 29.81
compression: 8.50 >>>>>>>>>> 8.50
pin diameter: .866 >>>>>>>>> 22.0
top groove: .048 >>>>>>>>>> 1.2
2nd groove: .048 >>>>>>>>>> 1.2
oil groove: .119 >>>>>>>>>> 3.0
piston weight: >> 355 g
clearance: .0030 >>>>>>>>> .076 mm (subtract .05mm due to precoating)
dome cc: -15.48
part: >> part number: >> qty:
pistons >> 3520211 >>>> 6
pins >> A86623514SN >> 6
rings >> 1212303780 >>> 6
locks >> 866043S >>>>> 12
mint condition, only one piston has been out. they have been precoated to prevent any problems of meltdown u might encounter.
i still have papers and everything.
gave 975 shipped will take 900 shipped now
PERFECT FOR TURBO!!!!!
Old Jan 31, 2007 | 07:02 PM
nismology's Avatar
Low or high silicon forging? Standard or extreme duty design?
And in case anyone else is wondering the pistons are about .020" overbore.
Old Jan 31, 2007 | 07:15 PM
out of everything u just asked the silicone and design is the only thing i did not mention.......compression ratio is 8.5 to 1 as stated under compression
over bore is stated as well, so obviously it is overbore. now as for the others: they are manufactured from 4032 aluminum alloy (high silicone), and not sure about design they were custom made for this engine and r capable of holding up to supercharged, turbocharged, and sprayed engines so would assume they r extreme.
Old Jan 31, 2007 | 07:21 PM
nismology's Avatar
I noticed the compression ratio after i posted and edited...i just mentioned the overbore because not everyone knows the stock bore is 95.5mm.
And the extreme duty design has thicker ring lands, uses buttons instead of locks, uses a zero silicon forging etc. so i guess these are the standard duty. Just wanted to clarify for prospective buyers. Good luck on the sale.
Old Jan 31, 2007 | 07:54 PM
10-4 on that, appreciate it
Old Feb 1, 2007 | 04:02 PM
Come on guys i know someone out there w/turbo wants these.
Old Feb 2, 2007 | 03:36 AM
getbigtony's Avatar
i'm sure they do, but that's a total rebuild. i think a lot of people would just put a thicker head gasket on and call it a day
Old Feb 4, 2007 | 04:39 PM
thanks for your input and helping with my sale
Old Feb 6, 2007 | 02:10 AM
getbigtony's Avatar
sorry; didn't mean anything by that
i'll make an attempt with this bump!
Old Mar 8, 2007 | 11:49 PM
someone needs these
Apr 16, 2020 05:15 AM
6spd4dsc
Mar 4, 2016 05:19 PM
imported_Nismo_max
Sep 21, 2015 07:24 PM
ballerchris510
Sep 11, 2015 05:29 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
