Interest in VQ35 ported/polished heads w/ JWT C2 cams?
Old Jan 20, 2008 | 02:05 PM
coinage's Avatar
EDIT: 2/4/08 price drop!
considering parting out the motor i am building... i have put a lot of money into this and i want to go to school, so all my goodies need to go, including the car.
Anyway, about the heads, I had them professionally ported by my machinist that has recently retired, nothing but top notch work from him. I had him clean up the intake ports and do some bowl work. The intake split is knife edged. Exhaust ports were also cleaned up and polished.
While he was in there he installed the JWT valve springs and shims.
All of the lifters/cam buckets are the correct height for a cold lash of .010-.013" with the C2 cams.
Cams themselves are 261/261 duration, and have .456"/.456" (11.5824mm) lift
http://www.jimwolftechnology.com/cus...asp?PartID=461
also, the cams will have sprockets/phasers come with.
Price is $1750 OBO
Edit: i will also be selling the rest of the engine... ~1000 miles on it, ARP rod bolts, 04+ block, timing covers,upper/lower oil pans. swap on your topend and sensors and it will be ready to go. $750 picked up.
Old Jan 20, 2008 | 03:48 PM
rroderiques77's Avatar
Demodded and Forgotten
Some one should jump on these. Bump that sh*^
Old Jan 20, 2008 | 03:53 PM
Jess's Avatar
SHIFT_In2D
Wow that is sweet! Great deal wish I had the cash to get this, but good luck!
Old Jan 20, 2008 | 04:52 PM
NmexMAX's Avatar
dot dot dot ...
Just wondering why you didn't go w/ HR heads?
Old Jan 20, 2008 | 05:17 PM
coinage's Avatar
cam availability? i never saw anyinfo on them until after these were finished
Old Jan 20, 2008 | 07:18 PM
accordingtou's Avatar
VQ30 DE T
Head work
What is the difference?
Any dyno/flow bench charts to prove the gains?
Nice pics. Nice light p&p. Did the machinest gasket match the lower intake ports?
Also how did he achieve the proper cold lash? grind valves or match the buckets? What angle valve job & valve seals did you use?
Did you happen to put these bad boys on a flow bench?
Overall you are selling them for a good price.
Old Jan 20, 2008 | 07:26 PM
coinage's Avatar
the im not sure how much he opened them up exactly... it is not gasket matched. I asked him to clean them up and do some bowl work.
to get the proper lash i bought new cam buckets for get the correct height.
oem seals and no valve job... I chose not to do them... already sunk enough money into these guys.
no flow bench
Old Jan 20, 2008 | 07:39 PM
VQ30 DE T
no flow bench
I hear yuh.
All the small things add up to a big reciept.
Still a good price though. Good luck with sale.
If you havent already ..Post these heads in the Z & G forums
Old Jan 20, 2008 | 08:16 PM
pbn85's Avatar
coinage your car looks fawking sick! cant believe your selling it...make sure to make a part-out list if you are taking that route
Old Jan 21, 2008 | 10:07 AM
coinage's Avatar
ttt..
as for a list,,,this is what i have so far:
heads/cams-$2000
long block- $750
Cattman catback- $450
Ksport coilovers- $500
LRMAF MAF- $100
SAFC- $185
PLX WBO2- $200
I also have a clutchnet 6 puck clutch and a clutchmaster pressure plate made for a 350z that i was gonna try out, they are both used with like 1500 miles on them- $250 for clutch and pressure plate
I would be willing to sell the cattman headers and ypipe if someone ships me a set of stockers before hand
Old Jan 21, 2008 | 03:57 PM
Deckdout2's Avatar
Play with my balls
sent pm.
Old Jan 22, 2008 | 06:48 AM
coinage's Avatar
ttt
Old Jan 22, 2008 | 07:03 AM
VQ30 DE T
What type of head gaskets are those?
Old Jan 22, 2008 | 07:10 AM
coinage's Avatar
oem 350z triple layer, they look copper because they have the copper sealant on them
Old Jan 22, 2008 | 07:11 AM
Puppetmaster's Avatar
PM sent....
Old Jan 22, 2008 | 10:06 AM
coinage's Avatar
replied...
Old Jan 23, 2008 | 08:25 AM
coinage's Avatar
ttt
Old Jan 24, 2008 | 12:13 PM
coinage's Avatar
bump
Old Jan 26, 2008 | 02:28 PM
coinage's Avatar
ttt
Old Jan 30, 2008 | 11:57 AM
coinage's Avatar
ttt
Old Feb 4, 2008 | 08:35 AM
coinage's Avatar
PRICE DROP!!!
Mahmuth
Aug 16, 2024 08:23 PM
litch
123
Jan 4, 2024 07:01 PM
mclasser
22
Nov 12, 2020 01:58 PM
jaydot901
Sep 29, 2015 01:18 PM
