Best Springs for 00 SE
Old Jul 12, 2010 | 12:18 PM
jroy3221's Avatar
Looking to drop the front about 1" and the back about .5", the reason I am looking to get springs is because i got 245-45-18 in the back and when i go over bumps they rub. I heard it is because my shocks or springs suck so i figured get some new ones. Also looking for a more aggressive look, I hear Tein H and Eibach would be the best bet for the drop I am looking for but i wanted to get more input. I also want ride comfort too, so tell me what you think.
Old Jul 12, 2010 | 12:26 PM
ChinoX's Avatar
Bring it B*tch!
From: Queenz, nYc CarClub: NYCMAXIMAS.ORG Website: www.ChinoX.net
Wrong section...but as far as "best" is concerned, its up to you...what maybe the best setup for you will not always be what works best for other people
Old Jul 12, 2010 | 01:22 PM
2000_MAXIMA_KING's Avatar
Wait a minute it rubs on stock height so you want to lower it?
Old Jul 12, 2010 | 02:36 PM
zero2sixtyZ's Avatar
You embarrass me.
http://forums.maxima.org/6886987-post2.html
Old Jul 12, 2010 | 03:05 PM
a33_ridah's Avatar
tein h tech and eibachs are a rather aggressive drop i think, not a "mild" drop
but its your sturts that are like blown (too soft) consider redoing both things not just springs on your busted struts.
Old Jul 12, 2010 | 03:40 PM
Chris Gregg's Avatar
Get Off My Lawn
Confused - why are either "aggressive?" I would consider H Tech (F 1.6/R 1.0) and Eibachs (F 1.3/R 1.0) a slight/mild drop. Eibach is the mildest drop I've seen...anything less should be obtainable through coil compression blocks. Maybe you're thinking about S Techs being more aggressive at F 2.2/R 1.6?
Old Jul 12, 2010 | 04:41 PM
jbrooks870's Avatar
+1
Eibach and H&R are slight drops, H-Tech and Progress are mild, S-Techs are aggressive IMO
Old Jul 13, 2010 | 06:06 AM
jroy3221's Avatar
Someone told me it rubs because of poor performance with the stock shocks or springs. I am going to have someone look at it before i order springs, i also heard i might just be able to do something to the wheel well
Old Jul 13, 2010 | 08:21 AM
^^^ No don't do anything to the wheel well, and you have to locate where its rubbing it might just be that you have worn out struts.
Old Jul 13, 2010 | 08:23 AM
anomaly117's Avatar
here's the drop on H&R sports, stock struts. junk in my trunk tho, a$s end is a little weighed down
Old Jul 13, 2010 | 10:12 AM
01GLEMist's Avatar
Lowering springs WILL lower the car. It's more than likely your struts that are bad.
Old Jul 16, 2010 | 08:12 PM
morako's Avatar
i want to lower my car also because of the looks. i like the way the h&r springs look. my question is where did u get them and how much. ive already replaced my stock struts.
Old Jul 18, 2010 | 12:20 AM
a33_ridah's Avatar
thanks fellas for straitening out my confusion about the drops...i WAS thinking tein S
on a side note, i am not happy with my vogtlands..1.4 all around drop. my ideal setup would be around 1.5 F 1.0 rear.
MaxLvr21
Oct 17, 2015 12:11 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
MaxiNoob98
Oct 2, 2015 10:13 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
followthadollar
Sep 27, 2015 01:06 PM
