NY 03 xenon to 01 headlight swap
Old Feb 20, 2016 | 08:05 PM
Theslaking's Avatar
I would like to grab a set of 03 headlamp assembly's and put them on my 01. Just curious as to what modifications will need to be done, if any. Before I purchase the new headlamps need to know if I should be grabbing any other misc. parts for the swap.
Old Feb 20, 2016 | 09:31 PM
Get all bulbs and harnesses. You'll need them.
Old Feb 20, 2016 | 09:43 PM
Decimus Meridias's Avatar
I did it on my wife's car not too long ago. Ended up putting spade connectors on the car side harness and plugging in to the headlight. Needed wiring diagrams for 01 and 03 to compare the two (red goes to blue, etc.). Wasn't too hard once I found the diagrams.
Old Feb 21, 2016 | 03:40 AM
Theslaking's Avatar
Thanks. I can definitely handle a bit of harness modification.
Old Feb 21, 2016 | 06:44 AM
ThomasofSodor's Avatar
If you wanted something to practice with i could sell you one of my old headlights.
Old Feb 21, 2016 | 12:09 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
If you have the headlamps you only need the wire harness, that's all, there should be a writeup around here in whatntondo and what cables to cut.
Old Feb 21, 2016 | 12:46 PM
Theslaking's Avatar
I'm not up for practice runs. There is no pressure to get it right which makes failure more likely. And if I do end up screwing up anyway - life's lessons are leaned best when consequences are harsh!
Old Feb 25, 2016 | 09:09 AM
King_Ten_Ahead's Avatar
https://maxima.org/forums/5th-genera...guide-diy.html
Should be a piece of cake with this link.
Cheers
lladnekj
27
Apr 27, 2016 09:07 PM
ColdCananda
Apr 15, 2016 01:13 AM
2014Maxima
Feb 25, 2016 07:55 PM
13r1an
Feb 23, 2016 10:59 AM
ColdCananda
Feb 16, 2016 03:50 PM
