Who has the most HP with their 2k2?
Re: Who has the most HP with their 2k2?
Originally posted by MaxSE2k
Just curious who on the ORG has the most HP in their 2k2 and what they've done to accomplish their numbers?
SR20DEN 313 hp - 337 tq
Originally posted by Hotnicks
I think there is a 2k2 on "juice" putting something like ~320fwhp!
I saw his post a few weeks back. I'll try to find a link to his post.
Re: SR20DEN also ran....
well i was there for both the runs and the wheel hop was horrible through 1st and 2nd so when the slicks come in so do the 12's later
Originally posted by IceY2K1
13.315 @ 108.31 06/21/02
13.536 @ 110.27 07/05/02
I'm betting he'll break into the 12's though, once he dials in everything and it cools off again.
Re: Re: SR20DEN also ran....
Does he have the RPM window switch setup?
Originally posted by emax95
250 FWHP NA is in the works
I've currently got a PR CAI, and I'm supposed to get on a dyno this week... I'm a tester for Warpspeeds Y-Pipe, which should be arriving next week, and not sure what mods should follow to get the best numbers. Was thinking high-flow cat (or no cat) w/ custom 2.5" b-pipe - maybe keep the stock rear section.
How are you getting 250? - if you don't mind
make sure you dyno with the CAI by itself BEFORE you dyno the CAI and y-pipe. we all want to see what the y-pipe gets individually.
I should be at about 220 FWHP right now(I did 215 last time). Then I am going to add a fed spec rear header, stillen Y-pipe and UR UDP. Then in a few months when the Z comes out I am going to try to swap the manifold onto my car and then possibly the Z's ECU. If this all works out I should be close to 250 FWHP NA. My luck I will hit 249 HP
Pardon my stupidity - but where would I find info on this fed-spec rear header? Google isn't turning up much.
http://forums.maxima.org/showthread....3&pagenumber=1
. I am just using a header off of a 2000 maxima. I am doing this in order to fit a 2000 stillen Y-pipe onto my 2002.
Originally posted by Greg's2kGLE
2000 headers fit a 2k2? Interesting
. I while back I had a thread on it. The 2002 gaskets match up with 2000 ones perfectly. I just ordeed a stillen Y-pipe and I have the gaskets and header on and hand.
Yep
Yep
i think.i have like 190 now...hahah...my car hesiatates at 4000 and doesnt quite pull as hard as it used to...mebby since im at 21,000 miles..i need some Fuel injector cleaner or something
Nice, let us know how it goes. I bet the rear header is going to be a b*tch to get off right?
You bet! It is going to be a PITA to get off. I am going to remove my intake manifold and then the bolts won't be quite as hard to get too. Luckly my car is new so the bolts won't be rusted out.
Posted HP
How can there be so much difference between the advertised 255 HP and the numbers that are posted here WITH performance mods? I know 255 HP at the block is not 255 HP at the wheels, but there shouldn't be that much of a drop. Is 255 HP simply overstated, or am I missing somthing.
Re: Posted HP
manual transmission cars usually have around a 15-18% loss through the drivetrain. apparently the 6-speed maxima is showing something more like a 19% loss. it may not be about the HP being understated. the new 6-speed transmission could just be inefficient.
Hogan trouble shot it by listening to a sound it made when the runners changed somewhere 4000 - 5500 rpm
TallTom
57
Oct 14, 2025 05:16 PM
DMan_2KMax
20
Sep 29, 2001 01:17 PM
