Auto tranny pros inside please!
Old Jul 12, 2002 | 05:43 PM
Maximam's Avatar
Ok here is the scoop. I just replaced the tranny at 40k miles for the slipping 1-2 2-3 TSB. Everything was great till now. Regardless of the car being hot or cold, when I start the car and put it into reverse to pull out of the parking space it goes nowhere till I rev it a bit then it starts to move the car and is ok till next time I turn it off. Happends everytime now. I checked the fluid and is ok, but I don't know whats wrong.
Anyone??
Old Jul 12, 2002 | 06:08 PM
spaaz14's Avatar
Sounds like GNissan Gnomes......
Old Jul 12, 2002 | 07:10 PM
Maximam's Avatar
Anyone?
Old Jul 12, 2002 | 09:01 PM
mdeal's Avatar
Ok. Can you handle the truth? Sounds like you are screwed and will need to take it to the dealership or to a transmission specialist.
The ESM hints at the control or solenoid valves are most likely causing the problem, but it could be just a cable adjustment. These are probably the parts the TSB was messin' with.
In summary, nobody here has the expertise to diagnose an auto transmission, due to its complexity, and your best bet would be to take it to the dealership, pay for them to inspect it, and tell you point blank what exactly the problem is.
Old Jul 12, 2002 | 09:08 PM
serin's Avatar
sounds like good advise. the only way to get a straight answer from them is to pay for their services. just make sure you take it to a dealer with a decent mechanic so it doesn't get worse.
the flip side is, if it turns out to be related to the tsb work, you should be covered under warranty and be refunded your up front cost of inspection.
Old Jul 12, 2002 | 10:39 PM
DrOmed's Avatar
I have THIS SAME PROBLEM!!
Hi,
Ive noticed this problem with my April 2001 mafg. maxima too. It has 21,000 miles and in the mornings it just kind of rolls back out of gear then catches (the catching is unnoticable though) Let me know what you do/think we can do.
P.S. Can you fill me in on your tranny replacement issues and process and ease of convincing etc.?
Thanks.
Dr.Omed.HID#4.
Old Jul 12, 2002 | 10:45 PM
Dario's Avatar
dont mean to scare you, but thats exactly what happened to me before the tranny went completely out. keep your ears out for any grinding during driving, believe me i heard it.
sorry for the bad news and good luck to you
Old Jul 13, 2002 | 10:47 AM
Maximam's Avatar
Well this tranny has about 15k on it. It is a replacement from Nissan because they found metal shavings in the original tranny. It no longer slips but now I have no drive for a few seconds when I put it into gear after sitting for an hour or so....even first thing in the morning.
I guess I'll go to the dealership and have them tell me whats wrong. I'll let you know.
Any other suggestions?
Old Jul 13, 2002 | 08:23 PM
Maximam's Avatar
TTT!
Old Jul 25, 2002 | 12:23 AM
DrOmed's Avatar
ANy News?
Hi, Im about to go to the dealer on the same/similar problem, just wondering if you have found an answer to what is wrong. Thanks.
Dr.Omed.HID#4.
Old Jul 25, 2002 | 06:55 AM
bill99gxe's Avatar
Evil Administrator - "The Problem"
Re: Auto tranny pros inside please!
Anyone??
This time insist on having a brand-new transmission, and contact Nissan NA and open up a case file, just so you are on the record....
tarun900
19
Dec 20, 2021 06:57 PM
AaronL
Aug 8, 2020 10:31 AM
fx4five
Oct 18, 2015 06:57 PM
fx4five
Oct 1, 2015 04:58 AM
