Installing the 2k SE tail lights
Old Jul 16, 2002 | 12:49 PM
leenas's Avatar
I've gotten a set of used 2k SE tail lights and want to put them on my car but looking at the explanation found on 5thgenmaxima.com i noticed it says you need some sort of sealer that looks like it rolls off kinda like tape. If i wanted to go to a car parts store what would i ask for to make sure i get the right kind?
I've done a search to try to find the answer but couldn't find it!
Old Jul 16, 2002 | 12:54 PM
ms.thicknes's Avatar
Re: Installing the 2k SE tail lights
i just installed my 2k2 tails that came with the black sealant...I didn't use both boxes of it and I have extra...if you send me postage....I send you sealant....
whaddaya tink??
nette
Old Jul 16, 2002 | 01:12 PM
leenas's Avatar
Re: Re: Installing the 2k SE tail lights
I just talked to the people over at Tustin Nissan when ordering my fog lights and they told me just to get DumDum rubber sealer so i guess my question is answered.
Thanks for the offer Ms. Thickness
Old Jul 16, 2002 | 02:05 PM
MaximaZero's Avatar
Needs non-Maxima Friends
if theyre used, they probably still got leftover sealant on them. that along with what sticks to your car should be sufficient. i just heated up the sealant before insterting the lamp.
Old Jul 16, 2002 | 02:44 PM
kjpierce's Avatar
just did mine
i just did se tails and they already had some on there and i just used one thin bead around the light. if you use too much it will be hard to push the light in and get it to seat correct. just be patient and work with it.
p.s. if you get any of that goop on your car,lights , or hands , use turtle bug/tar remover to get it off. it works wonders.
lata
kj
Old Jul 16, 2002 | 03:11 PM
Greg's2kGLE's Avatar
When you take off your stock lights try and use the existing sealer. I did that (along with some that came with my GXE/GLE lights). Don't forget when taking off the tail lights to use a hair dryer and heat up the edges to make it easier to pull out the lights. Otherwise, you will need A LOT of force to pry those things out. The hair dryer made it much easier.
Old Jul 16, 2002 | 05:42 PM
maximilion's Avatar
I just changed mine a few weeks ago. I think you can find the tape at an auto glass shop. Where I live it rains ALOT, so there was no shortcuts taken. I used the tape that came with the lights with the leftover guck that was on there. I say, the more the marrier, I don't want my truck to start leaking.
Old Jul 16, 2002 | 07:25 PM
kjpierce's Avatar
nice work
i wish i would have known that little trick, i thought i was going to break my hand trying to push it out.
hey paul/wendy, you should add this tip in your right up on your "how to"
kj
vingodine
45
May 21, 2016 12:46 PM
4doorGTR
Sep 11, 2015 04:09 PM
220k+ A32
Aug 17, 2015 03:57 PM
kirkhilles
Aug 8, 2015 10:53 AM
MikesChevelle
Aug 6, 2015 11:36 AM
