Bose Subwoofer Replacement
Old Jul 16, 2002 | 02:08 PM
jarturo's Avatar
Considering the replacement the Bose factory subwoofer with something of better quality in order to clean up some of the distortion at higher volumes.
Does this make sense, and if so what are some recommended speakers that can be swapped with the existing subwoofer?
Old Jul 16, 2002 | 02:14 PM
[maxi-overdose]'s Avatar
yup...the stock sub rattles too much. howeverm if u keep the sub there...regardless what sub u put in, its going to rattle. I would suggest to have a box instead of using the stock sub mount....
Old Jul 16, 2002 | 06:09 PM
maximilion's Avatar
Re: Bose Subwoofer Replacement
I'm with this guy. I too would like to replace the sub but I don't want a box in the trunk-those days of huge woofer boxes are over. I don't mind sacrificing a little volume for less weight and more trunk space. Call me old, but I think if you put a box in the trunk you're kinda just wasting space for when you really need it.
Old Jul 16, 2002 | 06:20 PM
tbirdrob's Avatar
It may be possible to put a small (8-inch) enclosed sub in the same space as the factory sub. I'm just not sure the deck would support the weight. The other question is: does the current system have enough power to run a larger subwoofer, or will you have to add an amplifier into the mix?
Old Jul 16, 2002 | 06:39 PM
swallac2
Some one around here had it done. Looked good too!! Do a search he had pics and all. I think I am gonna do the same thing over the winter or next spring (have to get it by the wife!!)
Old Jul 16, 2002 | 08:39 PM
Virus's Avatar
Can the factory amp run a JL Audio 10 ok?
Old Jul 16, 2002 | 08:42 PM
NYC2SD's Avatar
Yes, someone definately had it done, they replced it with a crossfire amp and had a small box custom made to enclose it. The set up harly took any space.
Old Jul 17, 2002 | 05:26 AM
2k2MerlotSE's Avatar
JUVIN's ride
Check this link out.
http://maxima.cardomain.com/member_p...=209230&page=4
6spd4dsc
May 9, 2022 12:30 PM
jskirwin
Jun 8, 2016 08:49 AM
melteye
May 16, 2016 12:02 AM
Maxinesdaddy
Aug 21, 2015 11:43 PM
starman9215
Aug 11, 2015 06:51 PM
