"Dealer" fix to rattle on right side of dash/A pillar
Old Dec 10, 2000 | 09:14 AM
jetdriver1975
Hey all - I had a pretty loud squeaking coming from what seemed like the pass. A pillar not to long ago. I had originally thought it was some loose clips inside the A-pillar - But.. the dealer put some foam in between the seam where the upper dash meets the lower dash. Take a look inside the Door Jam and see where those to pieces meet. We found that the two were rubbing against each other, and that it was subsequently causing the sqeaking to be transmitted up the A-pillar. They also put some foam backing behind the trim on the pillar. Hope this helps some of you - it might be worth a look for those of you with this problem.
BoyWonder
boomerbrian
Oct 31, 2018 10:25 AM
Vequity
Sep 10, 2015 05:26 AM
Colossus
Sep 9, 2015 05:46 AM
FanaticMadMax
Sep 4, 2015 02:45 PM
