Help! Berk Intake problem - bad.
I don't know if anyone else is having this problem, but I cannot seem to keep my berk intake on the throttle body. I tried first using the mounting bracket and it would pull it off and then I tried zip ties, which eventually pulled it off, now I'm just letting it lay in there with no mounting device. I thought since it was pointing down more it wouldnt pull off, but recently it comes all the way off the throttle body and my car acts like it has a blown MAF. I know this can't be good for the car to get unfiltered air, please someone help on what I should do about this. I guess I am going to put the stock air box back on today when I get home. I can't keep putting the intake back on. Help.
Re: Help! Berk Intake problem - bad.
http://integra.vtec.net/geeser/megam...I/motor_01.jpg
ya i know how it goes, i put the mounting bracket in the right place, it would just seem to pull the maf away from the throttle body...i thought that this was a problem with the mounting bracket, but then it did the same thing when i zip-tied it and then again when i just let it hang...it doesn't seem to want to stay in there and i dont know what to do about it...
I had this same problem with my stillen after nissan replaced my variable intake system. I believe when they did the replacement, the throttle body ended up a bit closer to the passenger cabin. Sounds like yours may be that way naturally.
Went through the exact same problem. Finally, I did what you did and disconnected the Stillen bracket, moved to a different place. Since I was changing to cai - I never "re-attached" the mounting bracket to the firewall.
What I was going to do was simply drill a hole in the firewall at the spot where the mounting bracket met the firewall, then screw the bracket to the firewall.
ya that sounds like something that i might have to end up doing, but id much rather not...i think im gonna put the stock air box back on, take it to nissan, since its under warranty, and tell them that whoever had this before me must have had an intake and i have noticed that the throttle body connection to my maf is a little weak....maybe they will fix it for me and then i can try again...if not id say ill prob sell the intake and forget the hassle...i cant stand this thing coming off and me almost stalling, etc...anyone else got any suggestions?
I'd just make certain you have it installed properly.
ya im absolutely certain that it is installed right...well i need to go to the dealer to have them check out my A/C anyways beacuse its making some weird clicking noises...so ill tell them to check that out too...
Cheers
AA
i have had no problem with the actual filter stayin on the maf adaptor, im having trouble with the maf adaptor staying on the throttle body and ive tried tightening the hose clamp as tight as i can, it still manages to slip out after a few days...
Cheers
AA
i didn't end up using the bracket because it pulled on the accordian section too hard. so i just zip-tied mine to that brace on the shock tower
cheers
tried that
well cobymoby what do u mean by pushing the accordian thing into the throttle body? im trying to push the maf into the throttle body....the hose clamp doesnt see to hold well at all....also i tried zip ties to the shock brace, it also pulled it out....i put the stock air box on today, i think my throttle body and accordian section point too low towards the ground...im not really sure what is wrong...
ballerchris510
Sep 11, 2015 05:29 PM
lux97Max
Sep 4, 2015 05:42 PM
