passager side window wouldn't go up
Old Jul 24, 2002 | 06:36 AM
Nyc2kMax's Avatar
I have a 2K maxima and all of a sudden the passager side window will not go up. I can use the button on the driver side to turn in up but if you use the passager side button it will not go up. The strange thing about it is that if you press down on the passager side it works. Have anyone else had this problem and if so any pointers!!!
Old Jul 24, 2002 | 06:55 AM
TimW's Avatar
The silent but deadly Moderator
dunno..
but the switches have failed before.. thats the first place to look.
Old Jul 24, 2002 | 07:07 AM
Nyc2kMax's Avatar
no the switches had no fail before this is the first time i having this problem.
Old Jul 24, 2002 | 07:53 AM
TimW's Avatar
well
you can start with the SECU and remove the window motor.... or you can check out the most common failure, the switch. I'm just saying, it wouldnt be the first time.
Old Jul 24, 2002 | 08:40 AM
NYC2SD's Avatar
Actually the first thing to look at is the window lock out switch. Make sure its not pressed down!
Old Jul 24, 2002 | 01:09 PM
y sleep's Avatar
I have a similar problem
The rear, right-side window switch has been fixed twice in my car and is acting up again. The window can be lowered or raised by the driver's button but the passenger's side works intermittenly (other windows work fine). I was wonderng if any other org members have had problems with the window switches? I
Old Jul 24, 2002 | 02:01 PM
xtantmaxima's Avatar
Funniest thing I've real all day . It's happened to all of us sometime or another where you spend hours trying to fix something and its something stupid like that.
Old Jul 24, 2002 | 02:30 PM
WILLSE's Avatar
u guys crack me up!
will
Old Jul 24, 2002 | 05:09 PM
mdeal's Avatar
That sounds like the power window lock on the passenger door.
Old Jul 24, 2002 | 11:30 PM
y sleep's Avatar
In my case it is not the power window lock. The dealer has fixed the same side twice now and it is acting up again.
Old Jul 24, 2002 | 11:33 PM
mingo's Avatar
i have that problem too.. i took apart the switch and saw alot of black stuff in there, sanded the connection until it was clean, slapped it all together adn it worked fine for the first few days.. the problem is back again.. i'm gonna get ready to buy a new switch...
Mar 12, 2020 12:06 AM
BrandonCause
Sep 14, 2015 10:41 PM
thenewguyy
Sep 12, 2015 11:12 AM
markevans999
Sep 10, 2015 04:29 PM
ef9
Sep 5, 2015 11:18 PM
